10-05-2014, 01:59 PM | #1 |
1957 GMC 4 speed trans and V8 bellhousing
I really do not want to sell this, but its wasting space when someone could really use it. This is a very hard to find 1957 GMC 4 speed trans and Pontiac V8 flywheel / bellhousing & clutch assembly out of a 100 series pickup truck. Not only is this super hard to find, this one only has 53,000 original miles and was working perfectly when removed.
Still nice and greasy and bolted to the engine except the trans itself which was separated to make it easier to move around. Everything is in the best possible shape you could ever hope to find - should be correct for 55-59 GMC models w/ Pontiac 288, 316, 347 & 336 engines. So, this has to be picked up in Arab AL unless you send a shipper after it - not sure what the weight is, but can weigh it if you are sending a truck. Zip is 35016 where its located. First 400.00 dollars takes it - probably worth 600 or more in its condition, but I do need the space so my loss your gain
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
10-12-2014, 07:58 PM | #2 |
Re: 1957 GMC 4 speed trans and V8 bellhousing
OK so maybe 400 is a little steep....offers?
11-19-2014, 05:49 PM | #3 |
question, got the trans stuff. I have a 57 GMC safari/camio or what ever the thing is called. Got it with a 282/4 speed in it, not original but want to get it as close to stock as possible. Do you have a motor/bellhousing/maybe font drive accessories?
I have a dealer correct a/c unit and figured out how to power steering it using 63 truck parts. I bought it in pieces and am close to finishing 2 project and want to start gathering parts. The truck was rigged bad but taken apart. Sheet metal i am handled and bed sides, but a few years ago I tried to buy a 57 GMC parts truck that had what ever ponitac engine and a 4 speed auto trans complete, drove 8 hours and it was sold from under me for fifty more bucks! Let me know Steve |
11-19-2014, 06:23 PM | #4 | |
11-20-2014, 02:28 AM | #5 |
something close would be nice, as long as it looks correct
Steve |
11-20-2014, 10:13 AM | #6 |
OK so the 1955 288, 1956 317, and 1957 347 engines all look pretty much identical; I do have a 56' 317 that is supposed to be a good running engine according to the previous owner, and I do know its not locked up - hasn't been driven in years, but still sitting in the 56 GMC it came in - never removed. These are not the plentiful Chevy engines, so they are considerably rarer and more costly. This 317 is 400.00 if you decide you want to consider it.
11-22-2014, 11:25 PM | #7 |
how complete? I would be starting from scratch.........
thanks, Steve |
11-24-2014, 10:27 AM | #8 |
Starting from scratch I'd say this is everything you need - shifter handle, trans, bellhousing, flywheel, clutch etc - the clutch, flywheel etc is all still on the engine so no worries. I can crate and palletize if you are not driving here
12-14-2014, 03:58 AM | #9 |
This 4 speed trans is sold - Pontiac V8 bellhousing, flywheel etc still available for 200.00
11-18-2016, 12:28 PM | #10 |
Hello iam new to this forum..I was going thru stuff and saw that you have a bellhousing for a GMC ... wondering if you still have it ?
11-28-2016, 12:49 AM | #11 |
yessir I do - still attached to the 1957 Pontiac 347 V8 too....
11-28-2016, 09:59 AM | #12 |
11-28-2016, 02:08 PM | #13 |
This specific 347 is not for sale but have a complete minus pullys 1956 Pontiac 316 available if you need one to build, or I have a partial 347 still coupled to a Hydramatic that was part robbed for various odds and ends but is mostly whole.
Aside from these engines, all I have is the manual trans bellhousing for sale. As you have already found, this bellhousing is tough to find, especially coming off a 44K original mileage engine like this one, so its 200 plus whatever shipping costs. I use FedEx and have an account discount so it will be as cheap as its going to be anywhere through them
11-28-2016, 02:12 PM | #14 |
How much for just the other motor that parts been robbed off of it .
11-28-2016, 08:08 PM | #15 |
[QUOTE=Oldmoe518;7781200]How much for just the other motor that parts been robbed off of it .[/QUOTE
Let me go to the bldg and see what is exactly missing from the 347. seems like I had to rob the belly pan off the top under the intake, and the intake etc is all still there of course, but that pan is gone, and not sure what else - maybe the distributor is gone and ? Let me see. The Hydramatic attached to it is just a parts trans as well - someone before me had robbed the oil pan and side cover and maybe the dipstick....
11-28-2016, 02:15 PM | #16 |
You by any chance go to Carlisle pa ?just putting that out there iam from Albany ny
11-28-2016, 08:12 PM | #17 |
not headed to Carlisle - sorry but these parts might can hitch a ride on a North bound haul by one of my buddies hauling stuff up and back - would be a hit or miss deal where you wait for the right trip to take him headed North near you and he'd bring for a cheaper rate maybe on his way
11-28-2016, 02:24 PM | #18 |
I want the bellhousing and the other motor and if you have the trans ....
11-28-2016, 08:13 PM | #19 | |
bellhousing is yours
11-30-2016, 03:50 PM | #20 |
11-28-2016, 10:21 PM | #21 |
Still interested in the motor ..... definitely want the bellhousing.....I think I have everything but the block.iam guessing with out checking ....will check in the morning .dose the flywheel and clutch come with the bellhousing ? I have relatives in Lexington VA ..that maybe could be a drop off point ? The motor came from a car , because of the automatic transmission...the truck 347 was a little different compression wise ...i think not sure but the blocks should be the same ? Ok .... Great about the bellhousing ...can't wait to get it !!!just let me know about the motor price wise .(what you want for it )....
11-30-2016, 06:02 PM | #22 | |
11-28-2016, 10:47 PM | #23 |
Just a thought the bellhousing came out of a 100 and I have a 1957 GMC 350 stub nose (coe) should be the same...???
11-30-2016, 06:04 PM | #24 |
Actually this bellhousing came from a 250 series now that I remember right - a 1 ton in other words. So will be exactly what you need for a 350 series. I never removed the bellhousing so I assume the clutch and all that stuff is in there - you will need that manual trans flywheel too right?
11-30-2016, 07:25 PM | #25 |
Yes I would like the fly wheel and clutch and bolts too.that would be great..
