Where did you find your LS?
I've been lurking for a while and reading up on swapping in a LS. I'm looking for engine, tranny and harness, I would be willing to buy a wrecked vehicle and go from there. I've been on CL and there's not much listed, where are good places to find a decent setup? Where did you find yours?
58 Fleetside 71 Cheyenne |
Boosted Member
Re: Where did you find your LS?
car-part.com
you're welcome. lol.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
My buddy found mine for me out of a wrecked truck.
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
meowMEOWmeowMEOW
In the time it takes anyone to read PAST this post, they could have already found a motor on car-part.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Found mine on Craigslist. There was a local U-Haul service hub that had pulled a ton of 4.8s out of wrecked trucks figuring they'd be useful as replacements when any of the other motors died. Except they didn't have very many dead 4.8s, so they had a huge stash of replacements they needed to get rid of.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
I found mine on Craigslist as well. However, it wasn't on my local CL. I had to drive about 2.5 hours away. It was such a good deal, it was worth the effort and the drive. I lucked out and was able to buy a complete truck. A tree had fallen on the truck but it still ran and drove. I was able to part-out the remaining good parts off the truck and essentially get my LQ4/4L80E for just a few hundred bucks.
I used to check car-part almost daily. Great sight.
I found mine on a local FB for sale page.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
Old member
10 minutes a way . Right here at home. Craigslist. Got motor 4l80e transmission, stand alone harness, ECU and motor mounts manifolds and o2 senors. Inline fuel pump and sold a lot of it. $2200.00.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Ebay, I called the company that listed it directly, and the guy cut me a deal if I just paid over the phone, instead of going through the whole online process, and you save a whole lot on shipping if you can have it shipped to a commercial address that can unload with a forklift.
Fabricate till you "puke"
I did it the hard way...parted a wrecked 2000 4wd. I sold all the parts from the old truck...(saved a few pcs for my 02 Silverado), & did not have a nickel ,in a running 5.3! I did not scrimp on parts going in, the heads were pressure checked/surfaced, & a fresh grind on the valves. The springs were replaced (blue springs). If you are short on time, look at the boneyard picks....I would do the same again, hell I dropped 30 lbs, just parting that truck? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
![]() Join Date: Aug 2004
I bought my first one ( 4.8/4l60e) from a local yard ( $1450 complete)...turned out to be a bad motor ( rust in cyl), bought the replacement from LKQ with 7K miles on it, since I already had the swap completed, the motor change out was easy and quick.
I didnt need anything but the fuel setup and mounts. hacked my harness myself and tune was mail order. I did mine in 2009, so not many specific parts being made at the time.5 years she has been going. probably got around 6K miles on top of the 7K she had.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
first one 10 years ago complete fan to tranny at a local yard 5.3. I wired it had a tune dropped in in and ran it never even removed the intake. I did need to clean the injectors. Still running strong now with a turbo.
Second 5.3 my buddy found on the real cheap so I have a spare. The 6.0 local on craigslist. They are easy to find.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
![]() Join Date: Dec 2013
craigslist. 04 6.0/4l80 with harness/ecm/accessories for 1k
CL from a truck dismantler in idaho. bought a rebuilt trans from a local shop.
#15 |
Found mine on CL too. A tow yard a couple hours away from me had a wrecked Yukon XL that had been sitting there too long and I got the whole thing for $1200. Once I'm done pulling everything for the swap I should be able to make most of that up parting out what's left. There are good deals out there if you aren't in a hurry and don't mind scouring the Internet lol.
#16 |
Ebay but called them direct to order. Saved some money. Only issue I had was that the engine was from the north east so it was rusted and the aluminum didn't really look so hot. Spent 2 days sanding and cleaning. My fingers still hurt. Will spend the extra money to get a local one next time.
#17 |
Thanks everyone for all the replies, need to start seriously looking.
#18 |
I went with a complete donor truck. In my case I also needed a chassis so it was a no brainer. E-Bay
Rob
My '47 C.O.E build |
#19 |
free; as long as i used it for my project.
#20 |
![]() Join Date: Sep 2005
got my 4.8 4l60e all the accorsies, starter comptuer and harness from a local junkyard 1100 buxs
#21 |
Being you are Fl. check out this guy. I bought one from him 3 years ago and he is still in business, he will try and sell you the "farm" so be sure of what parts you "need".
Marv Niceville Fl 850 729 5544. He was not the cheapest but he had a COMPLETE dropeout and I was tired of searching for partial units. He was on the way to the West coast so he delivered it to my door, I am sure I paid for it!!
#22 |
What did you put in the search bar on CraigsList
#23 |
Found mine on CL. I searched "5.3L" and a wrecked 06 trailblazer popped up. It had hit a tree on the front end, and while it totaled the vehicle, the engine still ran and the radiator was not compromised. Got it for $1800. I hope to be able to part out the rest of the trailblazer and get the engine/trans for free.
#24 |
CL and check local salvage yards.
#25 |
I picked up a high milage 6.0/4l80 with ecm and junk hacked up harness for $800.
59 apache sbss. 68 sbss. 57 belair"old man car". |
