05-16-2015, 10:21 AM | #1 |
What can be said about the 4-speed New Process NV833 overdrive manual transmission?
I did search the forum but could not find anything relevant.
So word on the street is the 1980-85 two wheel drive trucks may have had the 4-speed New Process NV833 overdrive manual transmission. (this being a popular Mopar transmission) 1st = 3.09 2nd = 1.67 3rd = 1.00 4th = 0.73 I currently have the 4-speed Muncie SM465 manual transmission, which only has 3 gears, the Low being useless for me and my driving needs. So it's just a practical 3 speed with a 1.00:1 tallest gear. First Gear - 6.55:1 Second Gear - 3.58:1 Third Gear - 1.70:1 Fourth Gear - 1.00:1 Reverse - 6.09:1 Have any of you done the swap, how difficult is it? Can I use my old bellhousing? here's some pics off the InterWebs Last edited by Gregski; 12-07-2018 at 10:20 PM. |
05-16-2015, 11:32 AM | #2 |
Re: What can be said about the 4-speed New Process NV833 overdrive manual transmissio
I can't say enough good things about it.
Available through '87 (at least, also available in 4wd Blazer) as RPO MY6 (New Process A833), it is smooth shifting (uses auto trans fluid) and durable. Factory Hurst shifter. Works perfectly with a 3.73 rear axle and P235 tires. I have 213,000 miles on mine. http://67-72chevytrucks.com/vboard/s...highlight=a833 http://www.hotrod.com/how-to/transmi...-case-buildup/ http://www.hotrod.com/how-to/transmi...-speed-tranny/ http://www.hotrod.com/how-to/transmi...-modification/ http://67-72chevytrucks.com/vboard/s...highlight=a833 http://67-72chevytrucks.com/vboard/s...highlight=a833 http://67-72chevytrucks.com/vboard/s...highlight=a833 etc K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-16-2015 at 11:50 AM. |
05-16-2015, 11:50 AM | #3 |
Search on A-833 here (40+ hits) and in Engine/Drivetrain (22 hits).
Good light duty trans, not a Hemi A833, great for low torque and moderate RPM. Most are Mopar bolt pattern and will not fit into GM belhoousings. The front bearing retainer is too big for most GM bells. Shfter is unique and hard to come by, Mopar truck shifters will work if modded. 2wd and 4wd, 4wd output shafts are a different length. That's a starter.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
05-16-2015, 11:52 AM | #4 | |
I got sum a readin' ta do |
05-16-2015, 11:54 AM | #5 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-16-2015, 12:53 PM | #6 |
Interesting option to the conventional car 4 speed as in the Muncie M21 or M22. But I wonder if it would stand up being behind a 454. I was/am thinking about putting an M22 behind my 454. I prefer a manual to auto but a TH400 is hard to beat strength wise.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
05-16-2015, 09:23 PM | #7 |
I have a 2wd one sitting in my shop. not sure what I will do with it. its a complete trans and bellhousing, only thing missing is the shifter. the bellhousing I have with it only fits it, but I have another bellhousing I'm using in a lancruiser for the wife, thats a hydro bell, and it has the boltholes for that trans or a regular gm one. if it was 4x4 I'd prob use it in the lancruiser rather than the sm465.
that bellhousing you posted has the dual pattern as well. it will take either trans.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 Last edited by v30crewcab; 05-16-2015 at 09:30 PM. |
05-17-2015, 06:47 AM | #8 |
The overdrive version of the A833 was never offered behind a big block. It's not a strong trans for torque motors. Keith tows with his because he knows how to shift one and his 4.3 is a good match.
I would like to try one behind my 250. I've got a 2wd hydro clutch and a 4wd mech clutch, and keep thinking my 77 with its 250 and 3OTT could use some love. Then again, with my knees, I might just swap in an auto trans.
05-17-2015, 11:01 AM | #9 |
I kinda figured that. The way I drive, I'd most likely kill that trans in a few days.
05-17-2015, 12:04 PM | #10 |
I'm confused were there two flavors of this trans cause talking to my Mopar buddy who is building a '71 Challenger race car right now so he knows his stuff he says those are great transmissions strong as hell and used by Mopars with the big blocks, FYI he is not putting one in, to this car I was just making a point the guy can wrench
05-17-2015, 02:05 PM | #11 |
If you have a later hydro bell on your SM465, it should have the dual bolt pattern (GM and Dodge) and can take any version of the GM NP833. The trans almost has the larger front bearing to utilize the same bellhousing, presumably a cost savings move by GM.
05-17-2015, 02:28 PM | #12 | |
05-18-2015, 06:26 AM | #13 | |
The version we are talking about, they flipped the gear clusters to give an overdrive, resulting in a super low 1st gear. Most of them are aluminuim, not cast iron cases (it appears the 4wd version may be cast iron), and will flex under heavy load, causing the shfts to go out of alignment. The revised shafts are much weaker than the original version. One of the shift levers is flpped to make this work. GM offered them behind 4.3's and 305's, plus the 6.2 diesel which was desinged to match the 305 in power. They are not a high torque drag race capable trans like the original A-833! Big block and slicks = bang!
08-08-2016, 04:08 PM | #14 | |
05-17-2015, 09:18 AM | #15 |
My father bought an 87 R10 short fleet brand new. 305 with that A883 4 speed. He loved it. I remember him towing his 66 427 Chevelle to the track with it. I was a little tike. I think he sold it with 125,000 on it, no clutch rebuild either.
Hard to find, from what I have seen here on the net.
1982 K10 SWB 1987 V20 - Sold - Doh! |
05-17-2015, 10:18 AM | #16 | |
... K
05-17-2015, 03:51 PM | #17 |
driving is in my blood
At the rate I've blown up muncies [first the oem sm465, then the M20 twice] I doubt the nv833 can be that much weaker lol. Its not all in how you drive them either. I was exceedingly easy on the 2nd M20 rebuild but torque to the wheels is torque to the wheels and sometimes they just can't handle it.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
12-07-2015, 12:19 AM | #18 |
Well today I got me one, it wasn't cheap and it wasn't close by, so I am broke but I am happy.
It cost me $950 dollars and a 350 mile drive each way. The guy would not budge on the price, in the end I asked if he would go for $900 and he would not drop $50 bucks, oh well. This is off of a 1982 Chevy 1/2 ton 6.2 diesel 2WD. I bought it from a guy who bought it from another guy. To sweeten the deal I had him throw in the bell housing, clutch & brake pedal assembly (just in case) and a transmission cross member off of a 1984 4x4 automatic. (more on that later). So there is a lot to talk about here, and this swap may not happen until Spring but I just wanted to share, and start asking some questions. Pic 1 - how it was listed on Craigslist Pic 2 - we found the missing bellhousing under an old tarp in front of the passenger seat Pic 3 - the loot in the trunk of my car |
12-07-2015, 12:24 AM | #19 |
So the first question / comment I have is regarding the mechanical clutch assembly bellhousing I got for this bad boy.
I was under the impression that these transmission used a hydraulic clutch assembly, and then this guy shows me this bell housing which indeed matches the bolt pattern of this transmission yet it has the mechanical linkage fork in it and no provisions for the hydraulic clutch slave cylinder. Again remember this guy does not have the original truck this came out of, so we were unable to take a look see on how this was originally set up, but he swears the bellhousing is original to this transmission and he bought them as a set. So could some of you more experienced folks comment on weather these transmission came with either a mechanical Z-bar like clutch linkage and or a hydraulic clutch or this mechanical setup is just not going to work for me? |
12-07-2015, 07:46 AM | #20 |
Both hydro and mech clutch versions are available, I actually have one of each.
The early ones, particularly 4wd, seem to be mechanical. For most of these the pattern on the bellhousing is unique to this trans, although there are some that apparently have the Chevy pattern. To check you have the correct bell, line up hte pattern. Then check if the front bearing retainer just slides into the bell. This is larger than the Muncie / Sagniaw GM front retainers and the bell should just fit it. This is critical to the alignment of the trans. I see you got the shifter, that's the other critical part.
12-07-2015, 09:03 AM | #21 |
85+ trucks are hydro clutch, regardless of which transmission it came with. You could get an 85+ SM465 bell. Or buy the advanced adapters hydro conversion bracket.
12-07-2015, 11:12 AM | #22 | |
once again I thank you for your feedback |
12-07-2015, 02:12 PM | #23 |
Moderator
The MM7 is the 4x4 version.
The MY6 is the 2WD unit you just bought . It's pretty much the same aluminum case NP A833 Dodge used in the Ram trucks with a GM input shaft and output spline count. Make sure the countershaft plug seals properly and the countershaft isn't rotating in the case.. And don't use gear oil in it. The shifter isn't that odd. It's an OEM side mount Hurst Competition Plus shifter. You can get them freshened up by Hurst if the shifter itself is terribly loose. If it's not loose clean it up and lube it. The Hurst plastic bushings and spring clips for the relay rods are available from Summit Jegs etc.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-07-2015 at 02:19 PM. |
12-07-2015, 05:43 PM | #24 |
Thanks bud, that helps I did not know what the model was I just heard of them referred to as Hurst shifters so that helps.
12-08-2015, 12:26 PM | #25 | |
Moderator
Fairly easy to re-work as long as it's not shagged completely out. The shim plates and springs are available. This guy is hawking his hardened shift rod bushings. They transfer the wear to the soft harder to replace parts. I'd just use the nylon Hurst Pit Pack bushings. 6 bolts is probably gilding the lily. The SM465 does fine with just 4. It's heavier than a dead horse.
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-08-2015 at 01:45 PM. |
