12-06-2015, 06:28 PM | #1 |
WTB High Idle Switch
WTB High Idle or PTO Switch for a 99-07. I need the switch, bezel and at least some of the wiring... Shipped to 65584.
This is located just to the right of the HVAC controls if the truck has it... Thanks! |
12-21-2015, 01:24 AM | #2 |
Re: WTB High Idle Switch
ttt...
07-31-2016, 01:51 AM | #3 |
ttt...
11-20-2016, 03:51 PM | #4 |
Bump
07-04-2022, 03:05 AM | #5 |
ttt...
08-02-2022, 11:49 AM | #6 |
depending on your engine and trans you can do this with a single wire into the ECM powered off the brake switch. I know on my 03 duramax I ran the wire and would just have to set the parking brake then you would hit the cruise button for one set point and the resume button for a slightly higher set point. Tap the brakes and it would cancel out, if it was in gear it obviously wouldn't engage, cruise would work as normal.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
