MI '69
![]() Join Date: Oct 2004
73-77 Blazer Front Drive Shaft Compatability
Now that I've sorted out which tailgates fit my 73 blazer. I need some help with the front driveshaft.
The LMC catalog shows 2 different front driveshafts (one with a u-joint tip and the other with a flange). Supposedly, the 73 requires the u-joint version. I've hard a heck of a time finding a used one but don't want to shell out $320 for a new one. There's a ton of the flanged shafts around so is it possible to just pop off the flange and mount it without it? The blazer is bone stock as best I can tell and has full time 4x4. Here's the page from the LMC catalog: http://www.lmctruck.com/icatalog/csb/full.aspx?Page=153
1967 Chevy (Project Frankenstein) 1973 K5 Blazer |
Re: 73-77 Blazer Front Drive Shaft Compatability
No they are different lengths but if you can't find them without it get the flange for your transfer case.
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
a jeep xj front driveshaft is the same style, but don't know if the length is compatable or not. those take 1310 joints, and the big round style is 1330.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
MI '69
What do I need to search for to convert the transfer case to the flange style output?
You just need the flange off the output it's just replaces the old yoke then you need a driveline that matches.I can't say whether the xj part will interchange or not but the early 70s squarebody 1/2 tons use a 1310 u-joint it would be a matter of length and if the cv joint will bolt up the same
just saw a 77 in the yard today with a 203, and the flange. just need to find a setup off one of those and you're good.
some front output shafts are fine splined and some are coarse, like 10 spline or around there, not sure, , you will need to pull yours off and see what splines you have, then find a flanged one with the same splines.I have had to do this.
Tags |
blazer, driveshaft, front driveshaft, u-joint |
