![]() Join Date: Jul 2015
Selling Lsa Blower and adapter plates
I am selling my LSA CTS V supercharger and cathedral port to square port adapter plates. These plates will allow you to bolt this blower to any gen 3 or 4 4.8l 5.3l or 6.0 liter engine with cathedral shaped ports.
The blower has 30k miles on it and I have installed the new solid coupler. Also comes with a throttle body adapter plate so you can bolt up any 3 bolt ls truck throttle body. It has a cable bracket on it so you can use a throttle body with a cable. You would still need a intercooler lid, fuel injectors, heat exchanger, heat exchanger pump, and olson kustom works makes an accessory drive bracket that will allow you to use your factory truck drive accessories for $340. He also makes fuel rails for these with a return line. Run this with a walboro 450 lph fuel pump and good to go. All you will need is some tuning. I am asking $900 plus shipping. You can call or text me at 315 430 0414 if you have any questions. Last edited by juddss; 12-18-2015 at 09:51 PM. |
Re: Selling Lsa Blower and adapter plates
OK 850. Just thought id throw them up here before I put them on ebay.
Where did you source all the adapters? I have an LSA supercharger on my Chevelle and if I remove the drive by wire this may be an option.
Science flies you to the moon; Religion flies you into buildings. LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/ |
Sent PM
Sent you a PM Juds, unless it already sold on Ebay.
Sorry the blower is sold. I got the throttle body bracket on ebay. It was made by LSX precision I believe.
Did the throttle bracket sell?
All of it is sold. You can find those throttle body brackets on ebay for about 50 or $60
Thanks J.
