01-09-2016, 10:42 PM | #1 |
Why can't I set my dwell angle properly?
I put in a new set of points (along with rotor, cap, condenser, wires and plugs). I checked them and the gap was correct at .019. Once running I checked with a dwell meter and it reads right at 40 degrees. I tried to adjust the dwell by turning the screw both directions. There was a noticeable change in the idle speed, but there was almost no movement on the dwell meter. It stayed very close to one side or the other of 40 degrees. I did this with two sets of points with the same result. I want to believe it is a bad meter, but it is a pretty basic piece of equipment. Is there anything mechanical I should check before investing in a new meter? This is a new to me distributor. Would wear on the distributor shaft cam cause this?
By the way, I know it will be recommended, but I do not want to change to HEI. Thanks for any help.
1972 K5 Blazer Cheyenne 1966 L72 Corvette Convertible 2016 GMC Yukon Denali |
01-09-2016, 11:07 PM | #2 |
Re: Why can't I set my dwell angle properly?
I would (personally) never stick a big HEI in one of these trucks if originality was any kind of goal. But I still also would never run points. That's why they invented the Pertronix II. Or heck, the Petronix III, though our tachs don't always like them.
I'd sure spend the money on an under-cap transistor breaker before a new dwell meter! Unless you do plan to work on a lot of points vehicles... but I gap them with a match book cover to get them running long enough to replace the points. Sorry I can't help with the actual underlying problem though.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-09-2016, 11:14 PM | #3 |
dwell should be 30 deg - is that what you're trying to adjust it to? are the points tight to the plate? Which screw are you adjusting? More detail and maybe someone can chime in with the silver bullet.
01-09-2016, 11:19 PM | #4 | |
Thanks.
01-09-2016, 11:42 PM | #5 |
i vote for the meter...you're obviously changing the adjustment if the idle is changing....some of the chain auto part stores like auto zone loan tools,i'd try that before i bought one...back in the day we'd just adjust it by ear till the idle was highest (probably not right,but thats how i was taught...never rechecked one with a meter...wonder if it was close)
1970 short step c10 leaf spring 454 |
01-09-2016, 11:42 PM | #6 |
thx. now I can see why you're asking! I'm stumped too. So you have another points care you can check the dwell on to confirm the meter is good?
01-09-2016, 11:52 PM | #7 |
No, my other car is a Transistorized Ignition car.
01-10-2016, 12:46 AM | #8 |
Just covering a base - but make sure you have the meter hooked up right. Last time I checked my dwell I coulda swore both leads went on the coil, and my meter was reading about 40 no matter what IIRC. Hooked the ground to the battery after re-checking the instructions and that got everything straightened out.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
01-10-2016, 01:08 AM | #9 | |
01-10-2016, 10:48 AM | #10 |
01-10-2016, 01:25 AM | #11 |
Petronics are known the fail in damp weather, like here. They might be good for CA and summer time, but Ive seen too many fail to depend of them.
A set of points, screwdriver and a match book and your back down the road. Grew up with points, Im not afraid of them. Tho both of mine have HEI factory distributors in them. I have a rebuilt points set up in a Faraday cage, just for giggles. and can swap it out in 30 minutes. As far as your dwell, pull the cap and see if the points are moving in and out. The screw assy may have stripped
Happy as a pig in mud |
01-10-2016, 05:24 PM | #12 | |
I have never had a failure. I live in SEATTLE.
01-10-2016, 02:34 PM | #13 |
You have to connect one lead to the neg side of coil that goes to the dist. The other is to ground. If you set the points at .019 the dwell will be correct. Another way to set them is turn the adj. in slowly till the engine dies. Then turn it 1/2 turn out.
01-10-2016, 05:52 PM | #14 |
I'm still running points. If your dwell meter is reading 40 and adjustments vary idle then set at 40% .and run it. Should be 30% but if the meter is off no problem. If the points are off it'll burn 'em and the coil after awhile. Then you can throw electronic's at it. No sense throwin' big money at it!
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
