01-30-2016, 08:56 PM | #1 |
Fitech swap on my 1972 K20
I have not done much to my K20 in a while, I had been researching fuel injection for a while and after my brother put a 6.0 LS in his 54 International, I knew it was time to bite the bullet and modernize my old carbureted small block.
.................._____ __________//___{\____ /__---____//____/__---/ .....(O). ..................(O). BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4 |
01-30-2016, 08:59 PM | #2 |
Re: Fitech swap on my 1972 K20
I figured I would show some pics of the current set up before the swap
01-30-2016, 09:03 PM | #3 |
Currently I'm running a 750 double pump mechanical secoundary, dart aluminum heads , headers , flat top pistons , and a 274 comp cam
01-30-2016, 09:05 PM | #4 |
Some pics of the new system I went with the tumbled finish in stead of the black, it's rated for up to 600 hp
01-30-2016, 09:08 PM | #5 |
More pics
01-30-2016, 09:13 PM | #6 |
This is the most up to date status, I'm currently waiting on the fuel command center to arrive from summit
10-01-2016, 11:05 AM | #7 |
Coopdog... Are you running the Comp Cams - Xtreme Energy XE274H ?
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
10-03-2016, 08:26 PM | #8 |
Yes yes, that's the one, it sounds great, would totally recommend it
10-03-2016, 08:27 PM | #9 |
Want to keep the thread alive, so here some recent picks
01-31-2016, 01:52 AM | #10 |
Subscribed! I have been thinking about how nice this would be myself.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-31-2016, 08:08 PM | #11 |
But Found Her 25yrs Later!
Also going this route.
01-31-2016, 08:13 PM | #12 |
I'm in!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
02-06-2016, 12:50 AM | #13 |
How's it going?
02-06-2016, 09:34 AM | #14 |
Sorry it's been a while fellas , I got a little busy with my school work, but here's some more pics . O2 sensor plate Tiged
02-06-2016, 09:37 AM | #15 |
Inlet fuel filter
02-06-2016, 09:41 AM | #16 |
Fuel command center
02-06-2016, 09:49 AM | #17 |
Hopefully today after wireing we will fire the old girl up
02-06-2016, 04:53 PM | #18 |
Cool.
Is your gas tank in the cab? If so, where'd you run your vent line from the command center?
02-10-2016, 12:49 PM | #19 |
Have you noticed any better mileage?
02-12-2016, 09:32 AM | #20 |
I have not gone for a true road trip yet because of all the snow and salt we just got, but when the weather gets better I will let u know
02-12-2016, 11:21 AM | #21 |
Hmmmmm......
I just looked up that Fuel Command Center and that is a slick set-up. You leave your exsisting low PSI pump in place and feed the FCC from it. It's a sump with a high PSI EFI pump inside, and you feed the feul injection with that. Nice & easy !!!! Thanks, now I have to spend more money !!!! "LOL" Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 02-12-2016 at 01:18 PM. |
02-12-2016, 05:53 PM | #22 |
Well fellas I'm into this deep so I figured I would treat the old girl a new set of slanted top value covers
02-12-2016, 05:56 PM | #23 |
, sorry about the dirty engine bay , Weeks been busy and neglected to give the old girl her weekly cleaning
02-13-2016, 01:52 AM | #24 |
what did you do with your return vent line from the FCC?
02-13-2016, 09:23 AM | #25 |
Did you have to run a return fuel line back to the gas tank ?
Also what about venting, do you have a vented cap or a vent line of some sort ? Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
