07-10-2016, 11:46 PM | #1 |
02 Tahoe door removal/install???HELLP!!!
Looking to replace some pass doors on a 02 Tahoe I picked up.I found some doors and when removing them from the donor I initially tried hitting the "pins"out to no avail...so my buddy that I got the doors from,said and did,pry up enough for the hinges to be "lifted" off the hinges??? I know this is not the correct way to do this and need to know how to remove the doors from my 02 the correct way and install the doors I got from my buddy.HELLP!!!
07-11-2016, 11:15 PM | #2 |
Re: 02 Tahoe door removal/install???HELLP!!!
The hinges have a bolt you must remove 10 mm, the stop bolt on the pillar, and the wiring. Then you lift the door, with the bolts out of the hinge it splits and half of the hinge is on the door and half on the pillar. Front and rear doors are mounted this way.
07-13-2016, 09:32 PM | #3 |
Yes I removed the bolt mentioned.so it is just a matter of "lifting"them up of the ones then huh?awesome thank you kindly for coming to the aide!
