09-21-2017, 12:47 PM | #1 |
BB oil pan indentations - need info.
This post/question might be more relevant in the engine/drive train section but there seems to be more such traffic here and I need info quickly.
Am finishing a trans/clutch, new rear main seal and oil pump check on a 402 BB and am cleaning the oil pan before paint/install. I have never removed/inspected a BB pan before, so am uninformed. This one has some indentations and I don't know which ones may be factory design and which are PO dents that should be banged out. Does the normal BB pan have an indent (about 3") immediately next to the drain plug (on bottom of pan toward the center and running lengthwise) and is the shallower part of the pan supposed to have a small oblong indent crosswise - and past it a small round indent - both centered on the midline? Thanks for any quick insight.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
09-21-2017, 12:52 PM | #2 |
Re: BB oil pan indentations - need info.
pictures would make it easier to help you out.
09-21-2017, 03:14 PM | #3 |
Doug*** Thanks, I thought about that - need to get it completely clean first and will try to post a pic if that becomes necessary.
09-21-2017, 04:58 PM | #4 |
Stock Pan image. Does this help?
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
09-21-2017, 05:00 PM | #5 |
Another angle
09-21-2017, 05:53 PM | #6 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
That indent is for the oil filter clearance...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
09-21-2017, 08:58 PM | #7 |
Thanks a bunch weg921 - that is perfect. Your pic shows that the minor ones I already have removed were needed, and now I need to bang out the dent just adjacent to the drain hole. It is a rather sharp crease and not easy to get to due to an existing baffle, but think I can get some of it, at least. Thanks again for the quick help.
09-22-2017, 11:53 AM | #8 |
Actually, the specific configuration of the bottom side of those two pictured BB pans is different - neither bottom is shaped exactly like mine (which I believe to be OE) - but both have the same important aspects showing that I need to press out one sharp dent. Thanks again.
09-22-2017, 12:05 PM | #9 |
Sweet, sometimes close enough works!
-klb
