12-13-2017, 05:00 PM | #1 |
4 wire cruise switch
I need the function for the 4 wires in the early GM cruise switch. I've got everything else lined up, but I need to verify which wire does which function for the yellow, red, green, and brown wires for this lever. In some old posts, I've seen switches that have a blue wire instead of brown. Anyone?
1972 GMC Jimmy 6.0/4L65 1972 Chevrolet long bed 1/2 ton |
12-13-2017, 10:28 PM | #2 |
Re: 4 wire cruise switch
Are you sure it's a factory switch? Factory switches don't have a brown wire, but many aftermarket ones do. What are you hooking this up to?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
12-14-2017, 11:39 AM | #3 | |
This is the style of handle you're looking for---> |
12-14-2017, 11:47 AM | #4 |
Check this link. It shows the cruise switch I'm talking about; http://chevythunder.com/fuel%20injec...ntrl%20pg2.htm
EDIT; I misread your question and though you had the old 3-wire. Never mind !!! :-) Last edited by hemi43; 12-14-2017 at 12:00 PM. |
12-14-2017, 12:07 PM | #5 |
ls1nova71, yes, it's an aftermarket switch. Its going in my Jimmy, which has a 6.0 LS motor and it's DBW. I've got my TAC wires set aside, but just don't know what the function is for the switch wires.
12-14-2017, 12:21 PM | #6 |
The Older Generation
12-14-2017, 12:22 PM | #7 |
This is my switch:
12-14-2017, 12:28 PM | #8 |
This should have the info you seek.... http://67-72chevytrucks.com/vboard/s...ght=cruise+dbw
12-14-2017, 12:24 PM | #9 |
This is the schematic I used when I did my 5.3 swap.
12-14-2017, 11:18 PM | #10 |
Are you using a factory switch or a dash mounted one?
12-15-2017, 12:04 PM | #11 |
I'm using an original Blazer turn signal handle with a late model 4 wire switch installed into it. It's wired directly to the TAC module.
The schematic of the switch I posted was to show the OP the colors of the wires and their function . Last edited by hemi43; 12-15-2017 at 12:14 PM. |
12-17-2017, 02:39 PM | #12 | |
This is a factory 4 wire switch that was used in the later trucks beforr they went to column mounted dimmer switch columns. It's the only NOS one I have ever had, and before anyone asks, no, it's not for sale.
12-18-2017, 11:06 AM | #13 | |
Again, the wiring schematic I posted of the 4-wire switch above with CORRECT colors was for the OP to have something to reference to when checking his aftermarket one. Most aftermarket companies use GM wiring colors as standard, and chances are pretty good that his aftermarket switch will work perfectly without the need of relays (assuming his switch is normally open) A quick check with an Ohm meter will answer this question. |
09-25-2019, 09:21 AM | #14 | |
blue, red, green, yellow my LS1 (2002 F body) is DBC and I have the cruise module from the car is there a link that shows wiring the cruise module to the pcm?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
12-15-2017, 12:55 PM | #15 |
It's aftermarket
12-15-2017, 07:09 PM | #16 |
12-17-2017, 12:50 AM | #17 |
Thanks man!
12-15-2017, 01:03 PM | #18 |
12-14-2017, 01:25 PM | #19 |
It appears that some people had to use the relays and some didn't. Are the relays just if you're running LED brake lights?
12-14-2017, 11:17 PM | #20 |
The relays are for when you're using an aftermarket switch. If you're using a factory switch they are normally open switches, but aftermarket switches are normally closed, so the relays are used to reverse the switches. You will need them to use the switch you have, just wire it like the way it shows in the link I provided.
12-19-2017, 05:21 PM | #21 |
My first attempt at wiring the cruise up worked like a charm. Very awesome to have cruise in a 45 year old truck! Thanks fellas. Y'all's instructions were perfect!
12-19-2017, 06:17 PM | #22 |
12-20-2017, 10:27 AM | #23 |
So which diagram did you use to wire it?
09-24-2019, 11:55 PM | #24 |
Hi All, really nice to see so much info but apparently my steering column is different.. It's a tilt but when I looked at the turn signal to pull it out, it does not have the set screw that I see in the pics posted, mine screws in...? Does that mean there is no way I can get my mine to work with cruise control for my 5.3 Vortech…? I sure hope I don't have to look for another steering column...
******************************************** In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks.. |
09-25-2019, 08:57 AM | #25 |
Can you post a pic of what you have? If it's a GM column it should work.
