12-28-2017, 10:22 PM | #1 |
Mongos 81 c30
this will be a very short build thread...I built this truck before I found this website and I didn't take many pics along the way..so ill just describe what I did and you can use your imagination for the rest..
12-28-2017, 10:31 PM | #2 |
Re: Mongos 81 c30
I had a need for a bigger truck to pull my Mahindra 50hp tractor so I went looking for a squarebody ton c&c truck..lucked up on this truck...it came from a local fire dept and only had 20200 miles on it when I bought it..it was kept inside most its life so there was no rust to deal with...it did have a bunch of holes in the doors from several different mirrors that had been put on it over the years...13 holes total in each door..the truck had a 350 with a sm465 trans and 4.10 gears...the truck ran great but lacked in power...
first order of business was to pull the 13ft utility bed off and shorten the frame..I cut a total of 5ft out of the frame..I bought all the metal and built my own cm style bed for the truck..sanded down the cab, fixed the body work and put a driveway paint job on it..the bodyshop i talked to wanted 7k to paint just the cab...i nearly had a heartattack..a lot of packages from lmc helped me redo the interior
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 12-28-2017 at 10:58 PM. |
12-28-2017, 10:39 PM | #3 |
Re: Mongos 81 c30
I had been curious about the LS swap for awhile but couldn't find anybody that would talk to me about what all was needed to do one..I finally found chris at lightning rod speed shop..he was a big help and hooked me up with a lq9 and walked me thru what I needed ....btw he does LS swaps and does an outstanding job from what I saw while I was at his shop...
I was on the fence on wether to keep the sm465 or not but I figured if I was going full bore why not step up to a nv4500.. so now I've got the engine and trans figured out so another order to advace adapters got them coupled together...the swap went very smooth..I was impressed with how simple it was..
12-28-2017, 10:46 PM | #4 |
Re: Mongos 81 c30
some pics of the truck as it currently is..
12-28-2017, 10:52 PM | #5 |
Re: Mongos 81 c30
and some engine pics after the swap..couldn't be more pleased with the power I've got..and od..and my mpgs went from 10 to mid 16s..winwin ...
12-29-2017, 09:28 AM | #6 |
It followed me home?
Re: Mongos 81 c30
I love it! Great job on the flat bed
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
12-29-2017, 07:32 PM | #7 |
Re: Mongos 81 c30
thanks Adam. .I ought to have my butt kicked for not taking pictures while I was building it...it came a long way from what I started with..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 12-30-2017 at 06:09 AM. |
12-30-2017, 05:11 AM | #8 |
Re: Mongos 81 c30
That came out very nice! What engine mounts did you use?
A good friend that is an LS swap guru, has been on me to 6.0 my 88 crew cab dually from the current 454. Seeing yours tempts me more! |
12-30-2017, 06:08 AM | #9 |
Re: Mongos 81 c30
thanks Doug. ..I used ebay mounts that put the engine in the stock smallblock location...
still got to get the ac hooked up...it'll have to wait for a while though...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 12-30-2017 at 06:14 AM. |
01-08-2018, 04:34 PM | #10 |
Re: Mongos 81 c30
Nice work Mongo! That thing is a cherry!
I'm gathering the last few bits to do the LQ4 swap on my '76. Planning to run the 3 speed for at least a little while until I find a good shop to build the trans I have waiting in the wings. Are you still happy with the eBay mounts? They're one of the few things I haven't pulled the trigger on yet. Just so many options. Been eyeing the Holley units that allow use of the factory SBC clamshells, but I'm not sure yet. I know I want some that retain the factory position though. |
01-11-2018, 02:24 PM | #11 |
Re: Mongos 81 c30
thanks....
the ebay mounts also use the clamshells and keep the engine in stock location..so far no issues...
01-11-2018, 02:26 PM | #12 |
Re: Mongos 81 c30
couple of pics of the coverlay door panels and dash cover.....
01-11-2018, 04:47 PM | #13 | |
Re: Mongos 81 c30
Headed to pick up my 6.0 in just a couple hours! It's going on a stand for a bit before I drop it in, but I'm getting close. |
01-12-2018, 05:12 AM | #14 |
Re: Mongos 81 c30
shiny don't mean much when you can barely see them....haha....
mine were similar to these https://www.ebay.com/itm/LS1-Convers...Syxe&vxp=mtrut mine are made of steel and was about 20-25 bucks shipped.......several years ago....they were not name brand
03-07-2018, 05:07 PM | #15 |
Re: Mongos 81 c30
That is a killer flatbed on that truck! How decent is your mileage while towing with that set up?
Also for a driveway paint job that you have done some great work. I helped my roommate paint his m3 after he got to know a guardrail on the track a little too well, and I quickly learned I am not a painter haha |
03-17-2018, 08:09 PM | #16 |
Re: Mongos 81 c30
thanks coveboy!!....for comparison with the 350/sm465 I got around 5mpgs while towing and 9-10mpgs unloaded.....with the lq9/nv4500 I get around 10mpgs towing and 16+ unloaded....all with 4.10 gears...
a driveway paint job was a nobrainer for me...a bodyshop quoted me 7k...just to paint the cab....I grin every time I hear a rock fly up and hit metal..thinking how my 300 or so dollar paint job looks
03-19-2018, 10:23 AM | #17 | |
Re: Mongos 81 c30
And daggum $7k?! With that you could just build an entire additional truck! |
03-19-2018, 10:45 AM | #18 |
I'm just glad to be here!
Re: Mongos 81 c30
Truck looks good Greg. Where did you get the Coverlay dash cover and door panels?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-21-2018, 04:56 PM | #19 |
Re: Mongos 81 c30
Ditto on the dash and door panels.
Also, where did you pickup the motor and trans?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24. /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
03-21-2018, 05:04 PM | #20 |
Re: Mongos 81 c30
I ordered the coverlay stuff straight from them..http://coverlaymfg.com/
the engine I got from lightning rod speed shop outta Chattanooga...it is a stock pullout..great guy to deal with... .. the trans I got from a place in florida...it was a fresh rebuild and dynoed trans.....but I won't deal with them anymore. ..
03-22-2018, 12:04 PM | #21 |
Re: Mongos 81 c30
Nice looking swap! Do you have a link to those coil covers?
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
03-23-2018, 08:16 PM | #22 |
Re: Mongos 81 c30
the only "link"to those is me....I made them....
03-23-2018, 08:39 PM | #23 |
Re: Mongos 81 c30
I LOVE red interior! Nice lookn truck!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
04-18-2018, 10:20 PM | #24 |
Re: Mongos 81 c30
Top notch job! I also like the fuel pressure gauge tucked up in there.
That pickup turned out super clean!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
06-14-2018, 09:46 PM | #25 |
Re: Mongos 81 c30
while going thru some old pics I found the only remaining pics of the old c30 from when I first got it..these were pics of the bed I pulled off...
