04-01-2018, 05:20 PM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Adding paddle shifters??
Was just poking around online and was wondering if anyone has added paddle shifters? I have a turbo 400 and I was wondering if anyone has ever done this? https://www.google.com/amp/www.hotro...fters-kit/amp/ this company allows you to add to most common auto trans.
04-01-2018, 07:08 PM | #2 |
Re: Adding paddle shifters??
That’s pretty cool, but for that money you could just about get a used 4L80 and TCIs kit. If your dropping $1500 might as well add overdrive while you’re at it.
04-01-2018, 07:23 PM | #3 | |
Sorry for the rant, my point is there are cheaper options. |
04-02-2018, 06:16 AM | #4 |
When I don't want to shift I drive an automatic transmission. When I want to shift I drive a manual transmission. When I want to paddle shift I drive a road racing car.
04-02-2018, 01:41 PM | #5 |
i have an LS swap and a 4l80 does anyone make a kit to add paddle shifters to that kind of setup?
04-02-2018, 01:51 PM | #6 |
Sure, but it would depend more on what box you have controlling the 4L80E and whether your harness has inputs for upshift/downshift wires.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
04-02-2018, 02:44 PM | #7 |
04-03-2018, 03:14 PM | #8 | ||
If you have the LS ecu controlling the trans it’s harder to add paddle shift. I know of some vans that have a “+” and “-“ button on the column shifter for manual shifting. But both of the vans I saw that in were 6spd trans and those 6spd trans are not really controlled by the LS ecu, they have a computer in the trans and connect to the LS ecu for data on stuff like throttle position, rpm, etc. If the shifter with + and - was available for 4l80 equipped vehicles then adding paddle shifters wouldn’t be too hard. You’d just need to know which pins were for the + and -, and correctly connect them to paddle shifters. Then you’d probably have to flash the ecu with the operating system for the vehicle with that style of shifter to get it to work. |
