Old 06-07-2018, 01:35 AM   #1
Nima
Blue 67
Talking How to level 67 C20?
What is the best (hopefully easier) way to level my 67 C20? Raising the front up or drop the rear down? I am thinking about an inch or inch and half on one end. I like the stock height. Can I just replace the rear coils with C10 or something else? My front steering and suspension is fairly new therefore the lower front end is what factory intended for these truck. Can I raise the some how without affecting the rid quality since my truck ride is not the best the way it is!
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 06-07-2018, 01:57 AM   #2
Aus69c20
Aus69c20's Avatar
Re: How to level 67 C20?
The springs in mine are stock with rear trailing arms. I put in 1 1/2” lowering blocks which leaves the truck with a slight rake. 2 inches would get you level.
If you want to soften the ride c10 springs may help.
Here’s a pic of my truck with the blocks.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 06-07-2018, 08:34 AM   #3
Nima
Blue 67
Thanks. Your truck has a nice stance. Do you know if C10 springs are just direct swap? Also, where did get your lowering blocks from? Are they just bolt ons?
Old 06-08-2018, 02:04 AM   #4
Aus69c20
Aus69c20's Avatar
Yep, as mentioned by northerngmc c10 springs are direct swap.
I got my blocks from performance online. But they shouldn’t be hard to find.
John
Old 06-07-2018, 09:10 AM   #5
rockyrivermark
Here's a short write I did when leveling my truck with blocks. not need to replace springs etc.
Very easy. See link
http://67-72chevytrucks.com/vboard/s...d.php?t=753458
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 06-08-2018, 01:54 AM   #6
northerngmc
northerngmc's Avatar
I used C10 springs on my 68 C20.
I wanted the truck lower and level.
I used 2" springs on the front and 4" on the rear.
C10 springs were a direct fit.
Before
After
I measured the height to the top of the wheel well and the front dropped 1.5" and the rear 4".
I also went with shorter shocks.
I didn't do anything about the pan hard bar. Seems to be mixed comments on whether it is needed with only a 4" rear drop. I couldn't get an adjustable pan hard bar for the C20 so I left the stock one in place.
Truck rides much better.
Front spring difference.
Rear spring diffence.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 06-08-2018, 02:21 AM   #7
Aus69c20
Aus69c20's Avatar
Northerngmc.
The ece panhard bars that go from the trailing arm to the frame fit c20’s.
I fitted one of the bent bars to mine in anticipation of a bigger drop. It seemed to stabilise the back end, or at least that was my perception.
If your diff is off centre, this is an option.
John
