68 C30 to 85 c30 suspension
Alright guys I'm working on my 68 c30 I got a donor 85 c30 for all front suspension. My true my question is are the c10 and c30 control arms different in 85? Cause if I can run c10 arms I will order some tubulars! Thanks for any info in advance.
#2 | |
Re: 68 C30 to 85 c30 suspension
1985 C10 arms use press-fit rubber bushings. 1985 C30's utilize the HD rubber/steel sleeve screw on style bushings. BJ's for C30 lower arms are HD & a larger OD. Upper control arm shafts are different because C10's use 1/2" mounting studs & C20's/30's use 9/16". You'll have to know/research what the aftermarket arms you're looking @ offer.
I think you can put the 85 spindles on the 68 control arms if you do not want to change out everything.
That is what I am going to do with my 71 because the 71 rotors are NLA
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
Thanks for the info you answered my question cause I was gonna see if I could just buy c10 aontrol arms. But nope I'll just buy some stock 30s and dehump them. I have Western chassis lowering spindles for an 85 as well.
What engine came with a 1968 C30 openroad camper, says big block?
#6 | |
73-87 parts swap over easily.
What's the best disc brake conversion?
