1968 C10 with coil springs, how to....?
My 1968 C10 does not handle loads very well, so I would like to beef it up some, not necessarily lift the rear end, just beef it up some.
Any ideas? Rick |
#2 | |
The Older Generation
Re: 1968 C10 with coil springs, how to....?
Some trucks had factory option helper springs. They come up for sale on the parts boards every once in a while. Here are a couple of pictures of them. The rear frame rails have been cut off in the second picture so it looks out of proportion. LockDoc
![]() Join Date: May 2010
Here's a better view of the one in the picture of my '69 C20 frame that LockDoc posted above.
I had the same issue with my '70 C10. Replaced the old stock coil springs with heavy duty progressive load coils & that did the trick!
1970 CST long bed Fleetside |
#6 | |
Old member
![]() Quote:
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=688743
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#7 | |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
![]() Join Date: Jul 2000
Lots of options here: https://www.truckspring.com/Search.a...n-Parts&page=1
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
I am doing a modest 2 1/2 front - 3" rear drop will the overload springs work with this drop or will I need to do something different? Maybe a pair of flatter leaf springs taken out of a car, cut and drilled to fit? Not meaning to hijack thread just thought it may be relevant.
#10 | |
https://www.earlyclassic.com/catalog...=139&keys=rear I also used these shock mounts to keep the shocks more vertical with shorter springs. Very important if you want the shocks to actually work! https://www.earlyclassic.com/node/1194 Doesn't look like they sell heavy duty drop springs, but they might be able to point you in the right direction. Call them at 888.777.0395.
Hey Rick, I was just wondering if you had made a decision on what to do with the back of your truck. I've got a 67 shortbed with the same issue. Thx, mike
To the OP: Moog #6101 springs should increase the load carrying capability without raising the truck up too much.
Concerning a rear drop AND increased load handling, I'd try lowering springs because they are typically stiffer than stock std duty springs. And if they can't handle a load, then take a look at the helper springs mentioned above or an Air Lift kit.
