03-24-2019, 10:28 PM | #1 |
Radio Delete Plate Clip Alternative
Has anyone come up with an alternative to the radio delete plate clips?
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
03-24-2019, 10:52 PM | #2 |
Moderator
Re: Radio Delete Plate Clip Alternative
Rare earth magnets work like a charm.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-25-2019, 12:19 AM | #3 |
Unless you have a compass on your dash.
03-25-2019, 12:36 AM | #4 |
Just thinking out loud here....Velcro?
03-25-2019, 07:45 AM | #5 |
You can cut down a lower body side molding clip and use a nut and washer on the back.
03-25-2019, 08:17 AM | #6 |
I have magnets now and after awhile the plate moves, I thought about Velcro but I do like the molding clip idea. Thanks.
It must be easy to keep a steady course with that compass setup.
03-25-2019, 08:36 AM | #7 |
Old member
Looking at this picture it should be very easy to make some clips for it. Cut 2 piece of sheet metal to fit as the original's do drill small holes in the center of each one and put a small screw in it. Place it in the right spot and take some washer that will fit the radio dial holes good and nut tighten it up your done.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-25-2019, 08:54 AM | #8 |
[QUOTE=Andy4639;8494146]Looking at this picture it should be very easy to make some clips for it. Cut 2 piece of sheet metal to fit as the original's do drill small holes in the center of each one and put a small screw in it. Place it in the right spot and take some washer that will fit the radio dial holes good and nut tighten it up your done.
I LIKE it. Thanks
03-25-2019, 10:22 AM | #9 |
Moderator
Rare earth magnets are very strong, I’m using them on a delete plate now and it does not move at all. If you are using plain magnets they will not hold very well.
03-25-2019, 10:37 AM | #10 | |
Did you put them behind the dash or in-between the plate and the dash? Where did you get them? Thanks again!
03-27-2019, 09:48 AM | #11 | |
I use them to hold my licence plates on so no holes in the roll pans. They keep my doors closed in the house and magnet fishing is a blast.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
03-25-2019, 06:52 PM | #12 |
You do have to allow for windage and current drift, though. Also the Magnetic Poles are shifting.
03-25-2019, 08:45 PM | #13 | |
As far as Command Strips, I'm married, I'm subject to enough commands.
03-25-2019, 10:42 AM | #14 |
So,, what else you got???
Velcro works great.....
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks.... Sorry, we CANNOT ship larger parts. Thanks.
03-25-2019, 11:02 AM | #15 | |
Sorry about the image size, not sure how to adjust it. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
03-25-2019, 01:52 PM | #16 |
[QUOTE=bill3rail;8494216]Yes, I made some. Not that complicated, just took way too much time. The tools I needed to buy were about $50.00 and I'll never use them again!
Sorry about the image size, not sure how to adjust it. Bill At least they came out nice. For what they go for, maybe you should make a bunch and pay off the tool.I wouldn't mind a couple of test pieces to evaluate. Just sayin...
03-25-2019, 05:54 PM | #17 |
03-25-2019, 05:55 PM | #18 | |
[quote=NewBayColony;8494340]
03-25-2019, 08:46 PM | #19 | |
[quote=bill3rail;8494471]
03-25-2019, 09:01 PM | #20 |
[quote=NewBayColony;8494593]Want to buy a hundred or two? No? That is what I thought. J/K
Very small market so it is not worth the cost. Bill
10-19-2019, 01:29 AM | #21 |
I used these body molding clips on my delete plate. Just get a fender washer to cover the hole from the rear.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
04-03-2022, 01:54 PM | #22 |
Could you tell me where you bought these and maybe a part number? Are they long enough to span across the plate and lock in there or did you have to modify them in any way, Thanks
04-03-2022, 09:45 PM | #23 |
Who was this question intended for? If you are asking me I bought them in the body clip section of the parts store I was working at "back in the day" when I first tried it . I think it was in the late 1990's. They are available in different sizes.
10-19-2019, 08:22 AM | #24 |
Bingo^^^
10-22-2019, 03:56 AM | #25 |
I used 3M Molding Tape.
AJC |
