07-03-2019, 01:03 PM | #1 |
Twin Turbo '66
Howdy,
I just now found this racing part of the forum, and thought i would stop in and say Hi. I just started working on my '66 that I call Lucky Sock. Is torn down, and starting to build the goods after driving it for about 2 years as a daily, 5.7 vortec swap truck. Will be a twin 61mm Turbo, Aluminum 5.3 LS and Th400 build. Going to be a alot of street driving, some track, and a few trips to mexico here and there for fun. As of now, just finished up getting the LS built and done and this weekend will start getting it set in the truck and finalize position and get the trans mounted up as well. From there will start mounting turbos, piping intercooler, radiator, new fuel system and all that jazz. It should be an exciting truck. |
07-03-2019, 02:27 PM | #2 |
Re: Twin Turbo '66
Right on nice build should be a fun setup, keep us up to date on it.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
07-03-2019, 04:53 PM | #3 |
Re: Twin Turbo '66
Very cool.
07-03-2019, 05:04 PM | #4 |
Re: Twin Turbo '66
I like it! (except for the part about taking that baby down to Mexico)
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
07-06-2019, 07:54 AM | #5 | |
Re: Twin Turbo '66
(Mexico is slang for "acceleration contests" on "public hard surfaces.")
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
07-06-2019, 10:33 AM | #6 |
meowMEOWmeowMEOW
Re: Twin Turbo '66
Mexico Illinois, St Louis Mexico, Mexico-St.Paul MN
And thats not even leaving the midwest yet
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
07-07-2019, 03:56 PM | #7 |
Re: Twin Turbo '66
We got the motor and trans dropped into the truck this weekend. Used new CPP perches, with Solid motor mounts bolted to Dirty Dingo Sliders. The Th400 tranny bolted to motor went in easier than expected. Its on a CPP tubular cross member with Polyurethane mount.
So shes in, and we have a whole lot room for turbo piping, especially since we are going to do a rear mounted radiator with external pump to put some weight in the back as well as clear up engine bay. More to come! |
07-07-2019, 08:46 PM | #8 |
Re: Twin Turbo '66
Looking good!
07-09-2019, 01:18 PM | #9 |
Re: Twin Turbo '66
Oooo Im in!
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
07-13-2019, 10:31 AM | #10 |
Re: Twin Turbo '66
Made it out to the shop today after work to work on the ol '66. First had to drill some holes for the new tranny crossmember and get that tight, then i could tighten up the perches after everything was straight.
The FTI stage 4 th400 with a brake looks pretty good sitting up under there! Next started to pull apart the old fuel system. The line is -6 with like a 250lph pump, and that wont cut it at all for the new setup. So got it all torn out, and dropped the tank. For the tank i need to drain it, and drill a hole for a bulkhead fitting so i have the ability to drain it when i need too. Since im running E85, and here in the midwest come winter time you cant get E85 for a few months, so need to be able to drain it and get pump gas for when i drive it during the cold. The New system will be going in soon, a bigger in tank pump at 450lph and -8 line all the way to the fuel rails. sooner or later will upgrade to dual 450's, but single will work while we get the tune laid out and some driving time on it. Slowly making progress on it! |
07-16-2019, 07:17 AM | #11 |
Re: Twin Turbo '66
sweet project! like the setup. what rear gears are you going to be running?
77 SWB 2wd. gutted, caged, slicks, not weighed yet 02 Duramax CCSB 4x4 12.7@104 6750lbs |
07-16-2019, 07:41 AM | #12 |
Re: Twin Turbo '66
Currently it has 4.11's with a 275/60/15 tire. Thats probably same tire i will run in slicks, or radials since they fit. But we may leave it, or may regear it for some 3.73's. Havent looked to much into yet, need to do me some research
07-18-2019, 09:22 AM | #13 | |
Re: Twin Turbo '66
Anything 3.0 to 3.50 will work great, I personally love the 3.25's in my turbo truck. With boost, you don't need a deep gear at all and the high gear gets that heat in the pipes for the spool much more efficiently. Awesome build!
07-18-2019, 09:38 AM | #14 | |
Re: Twin Turbo '66
the 4.11's we just through in there to have a little fun with the old Vortec that was in the truck when we bought it haha |
07-26-2019, 10:30 AM | #15 |
Re: Twin Turbo '66
I have done some tinkering on Lucky Sock past week or so, but mainly just wanted to show off me new parts i got. 417 Motorsports out of Missouri makes some badass parts! Owned by Blake Hughes who has an LS Turbo S10, thats won dragweek and hauls some ass. One of the nicest and most helpful genuises you could find.
I got their -8an threaded fuel rails made for my edelbrock intake, which are nice quality and were the same price as Edelbrocks fuel rails. They utilize stock length injectors which is another plus. The big beauty is their one of a kind designed water manifold block. With the rear mounted radiator and external water pump this easily allows you to only run 2 hoses back, as it is a crossover block. As well as having (2) 1/8" ports on top to easily dump steam crossover into as well as a pressure sensor or something else. It may cost more than just some adapter plates for the block, but you actually end up saving money after not buying as many AN fittings, and hose. Plus it just looks badass so thats a plus as well haha. More to come, the Truck should go to Chassis shop in the next month or so to get a 8.50 certified Roll Cage and maybe some other work done. More to come! |
09-20-2019, 08:00 AM | #16 |
Re: Twin Turbo '66
Find Super73's thread on his chassis. It was well thought out and looked good. I would blow the truck apart and box the frame and really think about a 4 link. The curved rear bars need to be straight to be effective at that length. Also you will want to ad a sill bar on both sides. I would do what ever you can with this cage that will allow you to update it SFI 25.5D. Some times you dont need the cage for how fast you go but for a stiff enough chassis to handle the power you have.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-20-2019, 08:23 AM | #17 |
Re: Twin Turbo '66
Thanks for the reply, and the comments on what your opinion. i'm open minded about it all and will take it into account. This is my first build so im learning and others have done it and have the knowledge and im happy they are willing to help out! I will talk to him and see what he thinks
I guess i should point out i'm not building a full blown race truck either lol yes it will see the track and the occasional race on the street. But its may purpose is to daily drive it to work and i would really like to do Rocky Mountain Race week. I guess i care more about building a fast fun truck that i still drive everyday and on 100+ mile trips. Realistically if it goes into the 9's ill be happy. I may build it more race worth later in life, but i'm doing what i can afford now being straight outta college and paying that off and buying a house haha. Appreciate all the feedback, it all is greatly appreciated! |
09-20-2019, 09:13 AM | #18 |
Re: Twin Turbo '66
That's coming along nicely. Why in the world did the PO do that to the crossmember?
NHRA Super Street 469C It only runs 10.90 at 156 mph |
09-20-2019, 09:18 AM | #19 |
Re: Twin Turbo '66
Lol i wish we knew. I wish i took better pics of it. Looked like they learned how to stick weld on it. It was some sort of a masterpiece thats for sure haha. There were a whole lot of....lets go with creative and questionable things welded and built on the truck when we got it
10-16-2019, 12:48 PM | #20 |
Re: Twin Turbo '66
Another photo dump for the guys that care to see the progress of the '66. We started the roll cage not too long ago and have been making some good head way for mainly just working on weekends. We got the main hoop bent and in, as well as the under bar that it sits on going over the driveshaft.
10-16-2019, 12:56 PM | #21 |
Re: Twin Turbo '66
We also got the two pillar bars done and in, this was challenging as we decided to go through the dash instead of around it. This was based on me being huge (6'6" 300 pounds) and want all the legroom i can get lol. just had to cut up the dash and it all fit like a glove! We then dropped it all so we could weld the tops of the bars and create a nice foundation to build off of from there. The windshield bar was bent up next and thrown in. From here we can start the back bars back to the frame as well as the front bars going through the firewall. More to come as we continue to get the cage built!
10-16-2019, 12:58 PM | #22 |
Re: Twin Turbo '66
Little sidebar on the '66 project. 1956 Bel air that my father in law is building to be a drag week car. BBC with Twin 88's should be one hell of a car. It finally got its chassis certification and now we are mocking everything up to get it all finalized before we blow it all apart to paint stuff! Im sure ill post more on it in the future as its a pretty badass car, and going to haul some ass for sure.
11-11-2019, 05:37 PM | #23 |
Re: Twin Turbo '66
Nice work.
11-12-2019, 04:16 AM | #24 |
Re: Twin Turbo '66
Cool truck and nice work so far.
On page 1 you have a post mentioning draining the E85 out because it’s not available during winter months. Not sure if you’re aware but the Holley has the ability to run a Flex Fuel content sensor that tells the ecu the ethanol content of the fuel. It doesn’t matter if you have a tank full of e85 or have it diluted down to 20% ethanol content the ecu will adjust the fuel trims for it. This is separate from the “self tuning” the ecu may do to maintain a target afr. Either way no draining of the tank or adjusting the tune for ethanol content is required when using a flex fuel sensor.
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla” 1967 Camaro 327 ‘glide cruiser “Bailey” |
01-28-2020, 10:30 AM | #25 |
Re: Twin Turbo '66
damn fine job so far!
