08-28-2019, 12:04 AM | #1 |
03 Tahoe Front Windows Not Working
New to me 2003 Tahoe:
the front door windows are not working at all. the driver door master switch will operate the rear windows just fine but not the fronts. when i click the front window switch the only thing that happens is that the right door makes a clicking noise kind of like a relay is clicking but the windows (either window) will not operate. i have tested this with a known good working master switch and a known good passenger switch with the same results. the problem with the clicking noise is that i am unable to click the master switch and isolate the clicking noise on the other side of the truck at the same time (arms not long enough) and i have no one at the moment to help me out. any clue what would cause ONLY the front door windows to not operate? If i didnt mention it, the rear windows work just fine. thanks in advance Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
08-29-2019, 11:03 AM | #2 |
Re: 03 Tahoe Front Windows Not Working
Are you sure the motors are good on those windows? The fronts always seem to go first since they get used more often.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
08-29-2019, 11:40 PM | #3 |
honestly no, i cannot be sure that the motors are good. i will double check them tomorrow. dude did say that they worked before he pulled the door panels off.
09-01-2019, 08:09 PM | #4 |
Moderator
Sounds like either the mechanisms in the front doors are toast....or the master switch wiring is not plugged on correctly....
If the mechanisms are toast, I use the ones off of Amazon....most economical really....about half the price of most auto marts... Easy to replace....about 30 mins per door....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
09-21-2019, 11:42 PM | #5 |
UPDATE:
As strange as it sounds to me, because i have bought 25+ of these trucks in the past 5 years, and never one time had a problem with a window motor, BOTH window motors were bad. I popped the door panels off and hooked 12 Volts to the motors and all they did was fizzle pop and smoke. not only are they bad but they were a fire hazard. I bought some Dorman replacement regulators with motors and just swapped them out whole. Problem solved. I will mention that i am not fond of the dorman regulators. they are supposed to be a direct replacement which they pretty much seem to be. However the quality is lacking as they seem to be very cheaply made and they are missing one complete mount point when bolting them up. I would probably rathered to have just the motors and replaced only the motors if that is even possible? I saved the bad regulators just to see if i can pull the motors off and replace them with new dorman units, maybe on another project.
