09-08-2019, 08:51 PM | #1 |
I got scared... Need advice
Hi all,
So yesterday I was out driving the Jimmy and I had to go a couple of miles on the highway. I'm doing 65 when some idiot does something stupid in front of me and I had to quickly away to the side to avoid hitting him. Very exciting, but unfortunately not that uncommon in my area. The scary part was the massive body roll. I turned slight left and sharp right as this happened. The front left part of the car dipped down so low that I was worried I was about to flip over. I kind of got out of it but now that I know the experience I don't want to have that happen again.... Ok so it was really scary and that made me wonder what I can do about it. Do they make swaybars for these trucks? I saw this stuff http://sokyclassics.com/product.php?section=1002085 Does any of it work? Is it straight boot in? Will it help for what I described? My 72 GMC Jimmy is stock 4x4. No lift or anything. I have relatively cheap shocks, kyb gas-a-just. I emailed Bilstein to get their shocks but they told me they didn't have anything that fits so I just put on cheap shocks for now. What do you guys recommend? Change the shocks (and if so to what?). Put on a away bar kit? Is there a holt-on kit that works and doesn't require require a bunch of metal work? Looking for advise. I won't go off-roading in this truck. |
09-08-2019, 09:01 PM | #2 |
Re: I got scared... Need advice
You can use a 73-up sway bar. If you use your truck off-road and want to keep the original travel in the front suspension you can use a quick-disconnect.
Here's a link that might help: http://67-72chevytrucks.com/vboard/s....php?p=4935792
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-08-2019, 09:03 PM | #3 |
I read on some other posts that those sway bars aren't a straight bolt on. Do they just go on? I won't be off-roading in the truck.
09-09-2019, 07:34 AM | #4 | |
also you will need the top spring u-bolt plates that have a stud on them to mount the sway bar ends to
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
09-10-2019, 07:37 AM | #5 |
A lot of the roll will be from the 15” tires. Even in the 28” range they have a lot of sidewall. What size tires are you running?
A set of 17” rims and 265 70 17 would be equivalent to a 32” 10.5” tire on a 15” rim. With two full inches less of sidewall. If you have a tire in the 30” range, a 245 70 17 would be 30” 9.5” 15 equivalent or close to it making for even less sidewall roll. I also would recommend a set of Bilstein shocks for your truck.
09-10-2019, 10:08 AM | #6 |
I've been trying to find Bilsteins, and they don't show any for the '72 Blazer/Jimmy.
Pat |
09-10-2019, 10:19 AM | #7 |
I have stock rims. I have a set of Yokohama geolandar m/t tires on, total height is about 31".
I can't find a set of Bilstein that fit. Any recommendations? |
09-10-2019, 05:44 PM | #8 |
May not hurt to look at your body mounts and leaf spring bushings. If they are shot that will could add to the body roll you are feeling.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-10-2019, 06:24 PM | #9 |
I think i have already internalized that my driving style and distances to cars around me has already changed....
New bushings and body mounts across the truck. I think my shocks aren't that great through. They where the cheapest i could find. would not mind a pointer to which model bilsteins may work -perhaps not to solve the body roll issue but to get a nicer shock than the cheapest KYB. |
09-10-2019, 09:38 PM | #10 |
BlahBlahBlah
If you don't have a roll bar take a peek at this thread if you haven't already.
http://67-72chevytrucks.com/vboard/s...d.php?t=619086 |
09-11-2019, 12:06 AM | #11 |
Addco makes sway bars for application, model 202 1" rear and model 141 11/8" front. Sorry to hear of you close call, thank god nothing happened. Your Jimmy is beautiful. Glad I got to see it in person before you took it home.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
09-11-2019, 08:21 AM | #12 |
If your springs are the original, negative arch type, that will give you roll also. Might want to opt for a minimal lift or at least an add-a-lift heavy duty base spring
09-11-2019, 05:03 PM | #13 |
It looks like addco offers an aftermarket kit that should work. I've been perusing their website and i am going to consider going down that path.
I drove the truck to a shop to check the alternator and tune the carb this morning and while i was driving i realized that i have changed the way i drive by a lot..... |
