10-09-2019, 06:37 PM | #1 |
Fuel injector harness
Hey guys hope you can help.
My 97 3500 7.4 Vortec needs a new fuel injection wiring harness. The OEM number that we came up with is 12163080. The problem im running into is that GM says its only $50 ish dollars. Now normally that wouldn't be a problem (Cheaper is mostly better)but when a bolt cost $25 compared to a wiring harness with all the connectors it doesn't seem right. Yes I have called and called AND call Chevy, Gmc, buick and no can answer the question of does all the injector connectors and clips come with it? |
10-09-2019, 07:01 PM | #2 | |
BMW & ASE Master Certified
Re: Fuel injector harness
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
10-10-2019, 10:31 AM | #3 |
When the connectors cost $8-12 each x 8 plus pigtail Im still kind of thinking that this part number is just the pigtail. Who ever heard of a stealership giving money away? Thanks tho.
10-10-2019, 02:55 PM | #4 |
The description says a lot about the item. It says harness. If it were just the connector, the description would be connector.
The part number 12163080 is the correct part number for the entire harness. It comes assembled with 9 connectors and the 8 clips. MSRP is 85.82 The small connector at the fuel rail is part number 12085491. There are 8 and MSRP is 27.07 each. The big connector at the fuel rail harness is part number 12125676. MSRP is 121.37. The dealerships don't make up the prices. They go by what GM tells them to list the part for. |
10-10-2019, 03:13 PM | #5 |
Thank you. You do understand why I was a bit skeptical right? I do appreciate that now I can order one.
10-10-2019, 04:30 PM | #6 |
10-14-2019, 04:26 PM | #7 |
Hard to beleive it is $56. I would have been suspicious too!
Tags |
7.4 fuel injector, fuel, oem wiring harness, wiring harness |
