Line bores
I have a old service replacement 327 small journal block I have been trying to unload.
Well I also have a 400 crank, and a bunch of other speed parts. So can I line bore a 327 small journal block to large journal? I know I can not turn the crank to small journal status. Just thought I could use what I have, and make it what I want. |
Re: Line bores
You should be able to trade it for a newer block easily. I'd make a 302 out of it for my Camaro.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Re: Line bores
![]() Join Date: Sep 2014
Re: Line bores
Re list it with Al's idea and I'll bet it gets more attention.
Who doesn't like a 7000 rpm small block Chevy? ![]() |
Re: Line bores
nice built 302 GM engine in a nice little street machine to whoop on ford 302 units would be so fun .
i was in a friends 99 ls1 / 6 speed camaro and passed a friend in his TRUE Z/28 302 car and he whooped my arss with out even trying . . . . ![]()
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
60-66 Nut
Re: Line bores
If in your 'other speed parts' you happen to have a 283 crank, you have the basics for a 302. I have a set of forged 302 pistons and a forged 283 crank, but have not been able to find a reasonably priced SJ327 block. Everyone around here thinks they're made of gold.
Re: Line bores
Set up right I don’t think a tunnel ram needs lots of cubes.
Buddy of mine runs a hi-ram on his 327. Some good info on hotrodders about set ups. https://www.hotrodders.com/forum/cam-523737-3.html |
#8 | |
Re: Line bores
I got the Holley Dominator tunnel ram with dual offset carbs. If I had a Wieland it would not be nearly as dependent on cubic inches to run decent. So I have to accommodate the best I can which is a great cam, and cubic inches to tame the beast the best I can. I will use dual Holley terminator tbi's to make it livable. |
Re: Line bores
Gotcha!
Two similar but different beasts! |
Re: Line bores
I think some sbc bottom cylinders were not machined for the counterweights on the crank.IDK when they changed but someone here will know.
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
Re: Line bores
Its the same as a 350 block, and those weights clear. Won't have any issues with a 283 crank.
Re: Line bores
A small journal 327 and a 350 block are not the same
Anthony |
