Gearbox spanner wrench
I know most people make something to use but does anyone know what size spanner wrench is needed to tighten up the front part of the gear box any help is appreciated thanks
Re: Gearbox spanner wrench
If you posted a pic of what you’re trying to tighten up I’m sure someone could suggest what wrench to use.
Thank you I uploaded a pic
The 2 holes in the front take a spanner wrench, but what size
#5 | |
The Older Generation
Good thing you posted a picture. I was trying to figure out where a nut would be on the front of a transmission... ![]() If I was going to buy a spanner wrench I would get an adjustable one. I have quite a few steering boxes out, but I can't get out to measure one at this time. https://www.amazon.com/Universal-Fin...04059106&psc=1 They have 3mm & 4mm pin ones. Whatever that is. LockDoc
I plan on buying a adjustable one just dont know what size pins it requires was hoping someone has one laying around and could slide a drill bit in the holes in tell me what diameter I need
#7 | |
![]() Join Date: May 2012
![]() https://www.amazon.com/OTC-1266-Adju.../dp/B000X8EGZE j
White K20 |
#8 | |
https://5speeds.com/cart/index.php?r...&product_id=70
Brass drift and a hammer, I’ve had plenty apart for rebuilding and never needed the spanner.
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
I'm aware there millions of ways to tighten and loosen it just figured someone has had to use the correct tool, I'm just going to use 3 bolts and 2 pieces of steel swiveled with one bolt
All about them K’s
![]() Join Date: Jun 2014
Regardless of what to you use to get the front nut loose, make sure you take the jamb nut loose first. That inner nut that takes the spanner won’t budge if the outer jamb is tight.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
