03-30-2020, 11:36 PM | #1 |
Cab rust
Just like everyone at some point in time, i got some rust on the back corners of my 62 c10. I have the bed off right now after just replacing all the bed wood and want to get it back on relatively soon. I also know i should get this rust fixed before hand. I’m by no means a body shop guy or a welder. But i was thinking of just filling these small holes with a welder and then grinding it down flat. Will that work? I am more of a rat rod type so it does not have to be perfect. But at some point i might want to give it a nice paint job. Advice? Thanks
03-31-2020, 12:32 AM | #2 |
Re: Cab rust
would be near impossible to weld rust holes up...cut out and replace is best option
03-31-2020, 06:06 PM | #3 |
Re: Cab rust
mongo is right. The metal there is so thin that you will be chasing it all over, even on low heat. You will need to buy a cab corner. General practice is to replace only as much of the original sheet metal as needed - don't use the entire patch panel. I remember replacing the cab corners on my dad's 64 and it had a lot less rust than yours and we replaced a tiny spot and I ended up chasing the metal around.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
03-31-2020, 11:52 PM | #4 |
Re: Cab rust
Not the answer i was hoping for. But figured that was going to be the answer. Thanks for your advice. Time to find a welder and buy some patch panels!
