08-25-2020, 06:51 PM | #1 |
Where can I find this part?
I'm not sure what it's called. It is the metal plate directly above the windshield on the inside and runs the width of the cab. Mine is rusted and I want to replace it. I see them for sale for pickups and Blazers but not sure if one is available for a 68 Panel. Anyone know where I can find one?
08-25-2020, 09:05 PM | #2 |
6>8 Plugless........
Re: Where can I find this part?
I think you are meaning piece 3 by your description. I think it should be the same for a suburban and panel truck.
https://www.lmctruck.com/1967-72-che...parts-suburban
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-25-2020, 09:54 PM | #3 |
Yes, Thanks! Most catalogs forget about Panel trucks in they're listings.
It's not rust, it's called patina Trying to bring a 68 Panel Truck back from the dead. 396 Big Block, 4 on the floor, and a whole lot of rust. |
08-31-2020, 08:47 PM | #4 |
OK, I ordered the header panel for a Suburban and got it today. It is different than the panel in my Panel truck. The Sub part has holes that look like they are for those nuts that clip into place (can't remember the name) along the top edge. Maybe a headliner or trim piece attaches there? I'm not too familiar with Suburbans. Anyway, my Panel Truck header has a smooth top edge that is folded over towards the roof. It also slightly wider. But, the length and the general shape of it looks ok and I'm planning to use it one way or another since a Panel Truck specific one is probably not available. The holes for the sun visors look similar in size.
My next question is, How is this thing installed? I know it is spot welded in place but was it installed at the factory before the roof skin. The reason I ask is that it looks like it is notched between the A pillars. Not sure if it will just pop in once I remove the old one. I guess I'll find out this weekend
08-31-2020, 09:28 PM | #5 |
That stinks it is different but that's probably the closest you're going to get for a new panel. I think I'd cut out your sun visor raised area and transfer it to this new panel. Maybe the center holes are the same and you can locate the old pieces on the new panel that way? You could probably cut the top rolled part off and cut your new panel and add it to it as well. Then it would look oe.
08-31-2020, 09:35 PM | #6 | |
