11-24-2020, 07:46 PM | #1 |
67 drum brake springs...replace em?
67 GMC with drums front and rear - Im doing a complete (except for the master cylinder) rebuild - shoes, hoses, and cylinders. I dont know if the springs have ever been replaced - they have a very thin coat of smooth rust on them - the truck was kept in a garage all its life (except of course when it was being driven). Should I replace all the springs?
Thanks in advance for all replies!
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
11-24-2020, 08:37 PM | #2 |
Re: 67 drum brake springs...replace em?
Every time.... if money will allow
11-24-2020, 09:12 PM | #3 |
Old member
I would. Considering they could be over 50 years old.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-24-2020, 09:18 PM | #4 |
Napa used to sell a complete spring and hardware kit for drum brakes.
11-24-2020, 09:19 PM | #5 |
Hi all, I am doing the same replacement, what about changing the drums?, I assume they should be changed, but thought I would check with you all. Thanks
11-24-2020, 10:15 PM | #6 | |
I’ve found replacement drums that don’t have the adjustment hole in them and you need to install a slot and plug in the backing plate. Best to keep stock ones. |
11-25-2020, 12:25 PM | #7 | |
Steve weim55 Colorado |
11-24-2020, 10:36 PM | #8 |
Great, thanks for info!
11-25-2020, 12:17 PM | #9 |
I no longer replace brake hardware on older drum brake (40s-70s) vehicles unless I can get my hands on NOS factory or aftermarket parts. Hardware kits (return springs) in the current auto parts chain have repeatable failure in my experience. Clean and inspect the originals carefully, they are almost always OK. You can't beat that old USA quality.......
Just my two cents of experience....... Steve weim55 Colorado |
11-25-2020, 12:25 PM | #10 | |
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
11-25-2020, 01:13 PM | #11 |
