11-26-2020, 02:25 PM | #1 |
Performance Lacking in a 383 Build.
Hey Guys,
I had my motor built from a friend who's (was), a reputable engine builder. Unfortunately, he recently passed away. The motor is the original 350 (to my Jimmy), and I did go with an Eagle 383 (B13005E-030), rotating assembly. The motor has Edelbrock RPM heads, and an Edelbrock aluminum manifold. Has the Pertronix ignition module in it, and a small RV cam in it as well. The cam is a "Howards" number CL113215-10 hydraulic roller. The original Quadrajet carburetor was rebuilt (76 jets), and placed onto the motor. The motor runs very well, but it just seems to lack power, and doesn't provide the "punch" I was expecting. I'm running 33" tires with 410 gears, behind a Turbo 350 transmission. Thinking of trying to go with a Holley carburetor and see if that makes any difference. Does anyone have a suggestion of which Holley I should use for this set up? Thanks, Pat |
11-26-2020, 02:39 PM | #2 |
Re: Performance Lacking in a 383 Build.
The intake, and holley won't add the punch your looking for.
My guess is you have 882 or equivalent shooter heads. Your cam is quite a decent going for a nice DD or torque motor. So he may of gone back to the low 8-1 compression your originally had, and the softens the whole hit of the bigger motor. You will have to take to top end off to see if adding 64cc heads will bump the compression up. Have you tried setting initial timing to 15*, and total to 36*. Stock D chamber heads need a lot of lead in due to the slow flame propagation. If that wakes your engine up enough for you. Then I would consider adding a dual plane high rise, and new carb. Or atleast add a 1 inch open spacer for a little more plenum volume. |
11-26-2020, 03:13 PM | #3 | |
The heads are Edelbrock 60995 heads. They have 64cc Chambers with 185cc intake runners. Valves are 2.020 intake and 1.6 exhaust. The intake Manifold is the Edelbrock Performer 2101 dual plane intake. My timing is right in line with what you recommend. Pat |
11-27-2020, 12:35 PM | #4 | |
Make sure you have fresh 93 octane gas in it. You should have tons of low end torque with your setup. Probably something simple like a vacuum leak. Last edited by garyd1961; 11-27-2020 at 12:42 PM. |
11-27-2020, 03:46 PM | #5 | |
It evens out afr, and smooths out the carburetor signal. Plus can reduce the needed size of a carb in many engines. Provides extra plenum volume some combos really need with out a manifold change. A 1" spacer on a Super Victor manifold is not the same thing on a Performer dual plane manifold. Where the concept really shines by comparison. Does it work on a dead stock low compression smogger 350. I have tried it, and got no where. This was a last tuning trick on a already well tuned engine. This is a worse case scenario, but I have done it on a built 350 that I had for a sleeper build I was fascinated in. It had Dart iron eagle heads with about 190cc runners, and 64cc chambers. Followed up with 9.5-1 compression, and pretty wicked circle track mechanical flat tappet cam. I ported a cast iron intake to get as much advantage out of as possible. When I got it running I had the Q-jet on the manifold as normal, and it was pretty wicked. After hours of needle, and other changes. Well a few weeks later I made a 1.5" spacer out of resin coated wood because of a article I read, and the truck was on the road fully as a back up vehicle. Plus I recovered financially, and emotionally from the project. So I had time to play again. Drivibility went up considerably, and felt power was across the board. Its hard to say in words, but the cam/carb combo was not ideal. Just when driving the truck when the engine was up to temp it had a bunch of flat spots in part throttle. The spacer smoothed out idle, and removed all but one of the flat spots. That flat spot was at just under 2750rpm under full throttle. Plus I had to lean the carb out again due to more even air flow. So mpg would go up. It got crap mpg anyways so it would be hard to confirm, but memory says it went from 11mpg to 12 mpg. Under the more idealistic conditions, but not really noticeable bombing around town. That engine drank gas. As for power before it could easily bark the tires hard in second. After it could continue the burn out into 2nd gear. HotRod, and Carcraft have a bunch of articles on how they work. Plus they hopefully can explain it better then I could. |
11-28-2020, 08:11 PM | #6 | |
I would leave it as is and find what the problem is. Get it running right and it still should have a lot of power. ETA, Some of you guys are suggesting a bigger cam someone even suggested one in the .600 range. That's fine if you are building something for the dragstrip but for a drivable truck on the street it's way too much. The motor should have way more power than needed with the current setup. Find what's wrong with the motor and fix it before changing the cam and intake. I'll bet once it's running right you won't want to change anything. Last edited by garyd1961; 11-28-2020 at 08:31 PM. |
11-28-2020, 08:49 PM | #7 |
11-27-2020, 07:54 PM | #8 |
I too have successfully used open spacers on dual plane manifolds. In my case it was on a .030 over 400 Pontiac with #62 heads I ported, a Ram IV cam and a set of 3 tube headers. After experimenting with several different combinations of spacers between the stock intake and the Q-jet I found that a 1/2" of stacked gaskets and metal plates that matched the intake holes topped by a 3/4" open spacer made the car quicker in the 1/8 mile. In addition and more important was that it moved the power band up slightly which made it easier to launch the car without spinning the slicks. Consistency wins races. And since it was my daily driver it definitely made the car easier to drive in the rain.
If the firing order of the engine and the physical layout of the intake manifold allowed exactly equal time between intake opening signals as they reached the carburetor then it is unlikely an open spacer would be helpful but since that isn't the case your trying to make the all the compromise work the best. The picture shows a stock Honda manifold and if you think about it, it's basically half a dual plane manifold with a spacer on it. Just laid out differently.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-26-2020, 03:12 PM | #9 |
It's not the carburetor, unless it was put back together wrong. A Quadrajet should be plenty of carburetor for that engine. Do you know what pistons were put in it? Which RPM heads? What's the compression ratio? The cam looks good, and the extra 33 cubic inches should be noticeable, but it's also possible it's a question of tuning.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-26-2020, 03:21 PM | #10 | |
Plus, the mechanic rebuilt the Quadrajet an has literally gone though hundreds, if not thousands of them. Not to say a mistake couldn't have been made, but probably unlikely. Damn....just come through your area on my Elk Hunting trip! LOL! Pat |
11-26-2020, 03:48 PM | #11 |
Do you by chance a mechanical advance only distributor?
Maybe a bad vacuum canister? |
11-26-2020, 06:14 PM | #12 |
It's not the traditional way, but consider taking the truck to a chassis dyno for tuning. It's the only way to really diagnose the issue in a deliberate way. You need data to know what to change. Could be a long list of possible causes. Could be fuel (need a wideband), could be timing, could be spark, could be the cam timing is off. Could be push rod length, could be airflow, etc.
Good luck! |
11-26-2020, 08:24 PM | #13 |
Everything you describe should give you plenty of power. Something's not right, but it's hard to tell what.
I had a guy bring a car to me once for lack of power. It turned out that the throttle cable was hooked up wrong and only opening the throttle 1/3 of the way. Sometimes it's simple things.
11-26-2020, 08:32 PM | #14 |
I have a 1972 gmc Sierra Grande k2500 which is my daily driver with a 383/ 35" tires and 4.10s/ Eaton rear end and a 4"lift. I had a holley carb in there and for the same reason I felt like I was lacking the punch I should expect in my motor. I recently switched to the Edelbrock AVS2 650 with in the last 2 months and it is like a whole new driving experience. Off the line, on the highway, pulling my trailers, driving up the mountain roads here in Alaska. Just completely different all the way around. I do have a few other upgrades but the new carb has really brought everything to life. I have no favorite between any of the carb manufacturers. They are all fit for purpose. I just happen to find one that worked for me.
*Side Note I did play with all the different calibration set ups in my carb that edelbrock offers with the tuning kit ( took a significant amount of time but was alot of fun). It took me changing to almost all the different settings. I kept detailed notes of each setting along with changing my timing for all of them to see what worked the best. I had my timing set at 0°, 4,6,8,12 on each different set up, and ran Them all. I finally found the best set up for my truck and all the time spent doing that was well worth it. I was able to have my 16 year old son help with most of it too, so it was a win win. I do have HEI, spark plugs gapped to .045, headers, dual exhaust, performer intake, Changed my thermostat to 190° ( which made a difference believe it or not). If you would like to know everything I did I would be more than happy to share. But for me the carb was what did it. Good Luck |
11-26-2020, 11:42 PM | #15 | ||||
Pat |
11-26-2020, 11:52 PM | #16 |
I see the intake as part of the problem. That's the short dual plane.....which works great on a stock 350 or my mildly warmed up 305. The Performer RPM or even the Air gap is what you want for a 383 or warmed up 350. Your combo is capable of breathing pretty heavy but that intake is not.
11-27-2020, 12:27 AM | #17 |
At the body shop.
The performer intake is fine. Ran one on a good running 400 forever.
" That didnt make it any newer " " Dont antique the equipment " |
11-27-2020, 10:19 AM | #18 |
I just looked up that cam.........waayyy wrong for an aluminum headed 383!! I have a slightly bigger cam in my 9.5:1 iron headed mild 305!
Change to a tall dual plane and a much larger cam and you won't be wondering where your power is. I have a feeling if we lined up with my little 305 at a stoplight you'd be VERY disappointed in your power. The motor as a whole is built well, take advantage of it. |
11-27-2020, 10:35 AM | #19 | |
11-27-2020, 01:07 PM | #20 |
Well, for starters he's got Edelbrock RPM heads with 64cc chambers! With that Eagle rotating assembly, that's OVER 10.5:1 compression! So, basically we have a VERY nice street strip smallblock with grandpas low compression smogger 350 RV cam in it! It's just wrong! It's like spending 75k building your dream garage and leaving a gravel floor in it......it's just wrong!
Change the cam AND intake, you will not know what to do with all the tire smoke! |
11-27-2020, 08:48 PM | #21 | |
11-27-2020, 02:58 PM | #22 | |
I'd like to hear the theory as well. Specs: 270/278 217/225 @ .050 .495/.500 w/1.5's 110LSA That combo should offer plenty of cylinder pressure for low end grunt. I didn't do the math on the combo but can. I would also recommend a dyno session if possible. A 2nd set of eyes going over everything might not hurt as well. Sometimes someone else will see something differently. *EDIT* Quick calcs w/some guestimating: 4.030 bore; 3.75 stroke; 5.7" rod; flat-top/6cc valve reliefs; .039/4.10 bore head gasket; .025" deck clearance; 64cc heads With a mild cam like that (34.5 IVC) & the combo mentioned; compression numbers 'suggest' around 10.4:1 static/9.18 Dynamic compression. The heads should still work just fine. The intake while 'small' for a 3.75 stroke SBC would still work but it won't offer full top end potential. Below 3500rpm? It should be very close to the RPM series of intakes. Calcs suggest ~400hp/5krpm based on 250cfm intake flow @ .500 lift. So if that's achievable, there's something possibly not set-up correct.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-27-2020 at 03:16 PM. |
11-27-2020, 01:36 PM | #23 |
Sure he might have 10 to 1.
But why is the cam wrong? Is it duration, lift, lsa? What numbers would you suggest are better? |
11-27-2020, 07:14 PM | #24 |
I'm sorry your friend passed away.
As to your engine delema I recommend talking to local racers about someone in your area who is good at tuning carbureted engines. As Skidmore suggested dyno time is a good way to go however it is expensive. And nowdays many dyno shops are not experienced with analog engines like yours. If someone immediately starts saying you need to change part XXX then go somewhere else. They are likely looking to up your bill because they are underhanded or they don't really know what they are doing and are hoping for the best. Ask them how changing this part will change the engine for the better. If they truly know what they are doing they wil be able to explain it so you can understand. Once all the avenues of tuning are explored then you can decide what parts might be changed to meet your goals. Try and remember the conversations you and your friend had about what you wanted from the engine. Maybe write them down. Your friend made choices about components based on those conversations and it may help whomever you find to help get the performance you desire. There are many ways to build an engine and 10 times as many opinions about those. There doesn't seem to be anything particularly wrong with your current combination so hopefully you can find something as easy as recurving the distributor will wake the engine up. As this goes forward you may have to pull the water pump off to verify the cam timing. Also be prepared to have to pull a cylinder head as any speculation on compression ratio is a waste of time until you know what the deck height is. These are the bad case scenarios. Worst case would be something like a cam lobe gone flat or rings that never broke in properly. Good luck and please post your findings.
11-27-2020, 03:03 PM | #25 |
Why would spending more money on parts be the solution to the problem, that's just guessing. Engines aren't that complicated. If it feels slow (but without an actual measurement and assuming 300hp) it's probably down 100tq/100hp. Unless something is broken, you won't see that kind of power loss with just
non-ideal aftermarket parts. With an "RV cam", you should see more peak torque than HP. This should feel snappy and fast when you step on it, even if it has falls on its face once you get moving. A dyno is probably $500, and will tell you a lot more than musical chairs with nice parts. It could also save you an engine rebuild, as a lot of power issues come with incorrect air fuel ratio. An old school guy may be able to tell you something similar with a drag strip, but that kind of expertise doesn't come cheap. With a good dyno tuner, you can also make some changes and run again. |
