WIW? 4WD skid plate and t-case
What's a nice original 4WD gas tank skid plate worth? Also a NP203 transfer case in excellent condition (looks like it may have been rebuilt). What's the high and low value for each?
![]() Join Date: Feb 2000
Re: WIW? 4WD skid plate and t-case
There's a separate page on here for WIW posts, http://67-72chevytrucks.com/vboard/f...splay.php?f=83
But for the NP203 they're not sought after (unless it has a 10-spline input) but I've never paid more than $100 for a working one with the trans adapter included.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
![]() Join Date: Mar 2003
Prob'ly about a hundred each. My question would be which gallon capacity tank does the skid fit
Not 10-spline. Tank is roughly 27" x 27" x 11.5" (not accounting for rounded corners) so about 35 gallons. Does that make it a Blazer tank? It came off a '74 shortbed 4WD frame but I don't know if it was originally under a pickup or Blazer.
#5 | |
I can't help much on the value. The np203 is probably worth the most to someone who wants to use the front gearbox bit as a doubler in front of a np205. The skid plate is of questionable value. I personally don't want to run one. The risk of rusting the tank out from trapped mud is worse than the risk of puncturing the tank, in my opinion. Some folks still want them, though.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
Interesting. It's a 1974 short wheelbase frame, were the Blazer and Suburban both available as shortbeds that year? Or would it just be Blazer?
The skid plate is from a Blazer or Suburban, there were no short bed Blazers or short Suburbans- I guess the Blazer is a short Suburban...
Like it was said already the pickups had saddle tanks and this would've been added by a previous owner or shop if they relocated a tank between the rear frame rails. Not factory for a pickup.
That’s not off a blazer I’ve seen and I’ve had many
Thanks guys, sounds like it must be a 4WD Suburban? The frame is date stamped 1974 and measures 182" tip to tip. Here are some pics.
I'd say its a Blazer frame. Blazer's overall length from bumper to bumper was 184.5" and a Suburban's overall length bumper to bumper was 218.75". The dip in the middle of the frame also looks like Blazer
Thanks for all your help MJN. I found this online and confirmed it's a Blazer frame—182" tip to tip.
