Heater core hose routing
What is the proper way to route the heater core hoses? Both of these are from low millage vehicles.
Active Member
![]() Join Date: Jan 2008
Re: Heater core hose routing
The pic to the right is correct, you can see in the pic on the left there’s a provision for a heater hose bracket which in the pic is being used by a zip tie for something else. Plus, you want it away from hot exhaust
Here is another photo I found of a 77 with 14k miles.
Possible both pics in post 1 are correct as one is with AC and the other without. Note that in the AC pic(black firewall), the heater core inlets are farther to the passenger side then the heater only heater core inlets(orange firewall).
#5 | |
There are several ways to do it and still be correct.
The only concern when hooking up hoses is where they connect.
Feed line to heater core comes from intake to bottom connection on core, top of core back to Water pump or to the rad. A/c trucks usually had return to rad. Length of hoses can be as short as possible or looped onto fender well. Also hose sizes are 5/8 for bottom core hook up, 3/4 for top core return line. |
![]() Join Date: Mar 2003
Looped to the inner fender is preferred as you do not want the weight of the hoses hanging off the heater core hose ends
As far as returning to water pump or radiator, I’ve noticed automatic trucks return to the rad. Presumably to help warm the transmission in cold weather. (The return is right above the transmission heat exchanger in the radiator.)
All manual transmission trucks I’ve seen return to the water pump.
-400/400 1979 K25 350/SM465/205/44HD/14FF 1985 K20 400/400/208/10/14 1987 V10 TBI350/700R4/208/10/10 '85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968 |
![]() Join Date: Feb 2000
The service manual shows the heater hose routings pretty clearly- it depends on if the truck is auto or manual trans as well. Auto trans equipped trucks use the radiator and manual trans trucks use the water pump.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Interesting that for the 350 v8 model the routing is shown behind the header pipe. It seams like it would touch the header pipe. If the header pipe is hot enought perhaps it would damage the hose.
