Old 04-02-2022, 09:45 PM   #1
BASE
BASE's Avatar
K10 front axle bump stops
This should probably be about the least of my worries, but it's been eating at me for a while. When I was cleaning up the front frame of my '68 K10 a while back I ended up pulling both of the bump stops out. One was already destroyed, and I did the second one in while removing it.
I haven't been able to find any replacements for these things anywhere. Are they just not made anymore? I've found some that look kind of close, but I think they are only listed for the back end of 2WD trucks so not sure if they would work.
Plan B is to switch to the newer stud mounted ones that seem to be widely available. I figured I would ask here first in case I'm just not looking in right places...
'68 K10 496/465/205
BASE is offline   Reply With Quote
Old 04-03-2022, 12:21 AM   #2
kwmech
Re: K10 front axle bump stops
Energy suspension 3.9103
https://www.suspension.com/universal-bump-stops.asp
Old 04-03-2022, 02:58 AM   #3
Richard
The rears look the same to me. I believe the bolt in style is listed for front and rear of a k10. If I were in your situation I would order the rear push in mounts from a place that allows returns and see if it fits. About $20 ea from what I have seen. If they do not work return them. Even with shipping back total loss will probably be around $30.
Richard
Old 04-03-2022, 08:31 AM   #4
BASE
BASE's Avatar
Thanks guys. I guess I won't be out too much to find out. Some of them have dimensions listed, and they all appear to be a good bit smaller than the ones I pulled out. They are probably cosmetic at this point anyway, since I put taller springs on it.
Edit: The MOOG K6607 is what I ordered. It looks to be a little taller than the others, and was available on Amazon of $15/pr. I'll try and remember to update this once I see how they fit.
'68 K10 496/465/205
Old 09-26-2023, 07:30 AM   #5
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: K10 front axle bump stops
I know this is an older thread, but I just replaced two of these on my 1970 Blazer that did the same thing due to being 53 years old. NOS on Ebay is pretty easy to find.
GM part number 3843849. Fits 1963-70 trucks
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
