01-01-2004, 02:41 PM | #1 |
Designated A-hole!
Bowtiebandits window regulator swap instructions.
Door vent window
1. Lower the window all the way 2. remove the door trim panel 3. remove the door lock knob 4. remove the screws which attach the vent window lower assembly to the door panel 5. loosen the inner and outer panel screws which are accessable through the hole to the rear of the lower vent pivot 6. slide the main glass to the rear, away from the vent window 7. turn the complete assembly 90 degrees and guide it up and out of the door 8. installation is the reverse of the removal Door window glass and regulator 1. lower the glass completely, remove the window regulator handle and the door lock knob 2. remove the door armrest and trim panel 3. remove the door vent window (above) 4. slide the main window glass forward until the front roller is in alignment with the notch in the sash channel. Disengage the roller 5. push the window forward and tilt the front edge up until the rear roller is disengaged 6. return the window glass to the level positionand withdraw it from the door 7. if necessary, remove the mounting screws and withdraw the regulator assemblythrough the lower opening in the door 8. prior to installation lube the regulator mechanism with chassis grease 9. installation is the reverse of removal Hope this helps.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-29-2004, 10:44 AM | #2 |
Its Magically Delicious
ok .. my regulator is stuck in the up position ... this is what the service manual says ..... i hope i can manage it the way the manual states
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
12-02-2004, 12:43 PM | #3 |
Alright Alright Alright
how do i remove the vent window?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
05-02-2005, 04:06 PM | #4 |
what would you suggest if the window is frozen in the up position ???
05-26-2005, 10:17 PM | #5 |
Designated A-hole!
Vice grips or a small pipe wrench.
12-06-2004, 11:32 PM | #6 |
Designated A-hole!
1. Shows where to remove armrest and handles.
2. Door without armrest and handles, prior to removing panel. 3. Shows the door panel gone, and where the vent window and regulator screws are. 4. The rest of the screws to remove vent window.
