04-03-2023, 11:43 PM | #1 |
Posi rear differential factory option?
A few questions here.they come from seeing a SPID for a 72 K-10, (4spd equipped) on a FB truck page.
The SPID listed a POSI Traction Rear differential. How common are the and/or are they hard to find? Whatever Gear would have been in this Rearend? ( I’m assuming it would be 4.10) If I were to find one, would it be possible to change the 4.10 to a more Highway sensible ratio (3.55 or lower )? Last question would be: what would the Factory Part numbers be? (So that I know that I’m getting an Actual POSI unit) My current rear end is a “One Wheeler” and I’d sure like to change it over to a POSI unit. |
04-04-2023, 01:17 AM | #2 |
Re: Posi rear differential factory option?
A pic of my spid on my 72 K10 from my build thread. https://67-72chevytrucks.com/vboard/...2&postcount=14 Originally factory posi and 3.73 gears. If the gear ratio is not listed on spid it would be standard. Not sure what the standard gear is on a 72 4x4, would have to do some research. Believe the cutoff on the carrier is 3.73. If you want higher gears than that a new carrier is required or a carrier with higher gears than 3.73. Probably easier to get a new posi unit of your choice to go with new gears. Unless you are looking to only have original OEM parts in the truck there is no reason to install a 50 year old used posi unit. The clutches most likely will have significant wear. Who knows? You may get lucky. Just in cast you are not aware the carrier is the differential or Posi.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-04-2023, 07:23 AM | #3 | |
I was kinda wanting to find a complete Posi rear end, Rebuild it, and swap it with my current one. BUT, if it’s more feasible to purchase a NEW Posi third member, put in a 3.23 Gear (for a little better Highway rpm), I’ll do that, since I’ll be tearing it apart anyway. When you say “Higher Gears”, are you meaning going up in the number (as in 3.73 to 4.10), or the other way (as in going to 3.23) There are other questions with every one answered. |
04-05-2023, 02:50 AM | #4 | |
If you have the higher gears and wanted to go to 3.73 or lower there are some companies that manufacture gears with thicker rings allowing the use of the carrier.
04-04-2023, 01:26 AM | #5 |
Mine was a non-posi. I purchased a new aftermarket posi and installed it using the factory 3.73 gear set. It was tight enough that I could torque the wheel lug nuts with both wheels off the ground and the transmission in park. I have been thrilled with the new one.
BTW I have had a couple of truck that were factory posi. I believe they were a fairly common option. Cheers. |
04-04-2023, 08:28 AM | #6 |
Look for a posi in a hiway-friendly ratio. Posi was available in an ratio. Personally, I would look for a more recent 12-bolt factory posi in 3.42:1, since ratios jumper from 3.73 to 3.08 in these trucks. 3.73 may be too grunty and 3.08 may not have enough grunt. 3.42 is the perfect sweet spot for running w/o overdrive yet works well if you do go with overdrive in the future. Probably your best bet would be buy an aftermarket performance posi, like Auburn gear
GM also offered posi for the front of the K-models, although seldom seen
04-04-2023, 08:41 AM | #7 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-04-2023, 09:52 AM | #8 |
I have a factory posi unit sitting on my shelf. I traded the old interior out of my truck for it. Of course this was right after I rebuilt the rear end. So when ever I do the 5 lug swap, Ill put the posi in the rear end.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
04-04-2023, 12:08 PM | #9 |
70+ ( Old Skool Club )
I put an Eaton Tru-Trac in mine when I had the rear rebuilt.
https://www.eaton.com/us/en-us/catal...ferential.html
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-04-2023, 12:26 PM | #10 |
My '68 has factory posi wit 4:11's. Not sure if posi is an upgrade option then or not.
04-04-2023, 10:52 PM | #11 |
according to the 1972 Truck Price and Facts book, the K10 with 350 engine came with standard 3:07, optional 3:73 and that's all. Perhaps "special order" one could get other gears
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
04-05-2023, 02:53 AM | #12 |
Thanks, have not looked into this. The 3.73 gear option on my spid helps confirm your finding.
04-05-2023, 06:29 AM | #13 | |
When I add posi I go with Auburn Gear or Detroit Tru-Trac, meaning go into rear end work. The trucks with factory posi I have run either came in the truck or I swapped whole rear. I have a later 3.42 posi to install in my '67 hot truck project and am now considering 3.73s and Tru-Trac behind the M22
This '72 I had not nearly long enough had a 292/4spd/4.10s/fr & rr posi, all listed as options This '72, also owned but a short while, had 350/4spd/3.73/posi rear, all but 3.73 were listed as options
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-05-2023 at 06:37 AM. |
04-05-2023, 03:09 PM | #14 | |
04-05-2023, 04:26 PM | #15 |
On this 67 short bed the posi is listed on the spid with 3.73 gears , it's a 292 3 speed on the column . and has the posi red tag on the diff .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
04-05-2023, 07:53 PM | #16 | |
The yellow '72 had TH350 and 3.08s and factory fr & rr posi. The green '71 had 3spd (changed to TH350) with 3.73s and factory posi. I installed detroit locker rr & TruTrac fr. This was early 80s, both truck original when I bought them, same as the two sort beds
04-05-2023, 09:10 PM | #17 | |
OP, I haven’t seen anybody else say it, but if you change the rear gear ratio in a K truck (4x4) you have to change the front to match. Several people have mentioned the 3.40/3.42 gear, but I don’t think you can get that ratio in a Dana 44 gear set for the front. Unless someone has removed it, the Dana 44 in the front should have a ratio tag specifying what gear is in it. And if it is anything other than what that engine combo came with stock, it will be an option on the SPID.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 04-05-2023 at 09:17 PM. |
04-05-2023, 04:52 AM | #18 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Both of my 72 C/10's had factory 3.08 gears, both were factory series 3 carriers, one with the factory Positraction. Factory Positraction I installed a "thick" set of 4.56 gears in the factory unit and race it. My daily driver, the other 72, I went ahead and installed an Eaton series 4 carrier and a set of 3.73 gears. That was/is my tow rig/work horse I beefed up by welding the axle tubes and using a cover girdle. I like the Eaton Posi's because they are rebuildable and period correct. The new Eaton carriers are stronger than the factory carriers GM installed until 81 when the 12-bolt was discontinued. The "Truck 12-bolt" in my opinion, is just as strong as the Ford 9"s as long as they're backed up with cover girdles. Back in the day before every soccer mom drove a 4x4 the two wheel drive Positraction was king!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
04-05-2023, 06:59 PM | #19 |
Grumpy, thanks for the picture, I've been looking high and low for the plug tag, any suggestions??
great thread guys, love all the info
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
04-05-2023, 08:28 PM | #20 | |
The hard part to find is the rear diff plug with the shoulder the tag fits on . Here is a thread with more info . https://67-72chevytrucks.com/vboard/....php?p=8798887
04-06-2023, 12:49 AM | #21 |
A scan of the back cover of a 72 Chevy truck brochure I have in hand. Hope it is readable. Odd that it lists 3.73 as standard on the K10. Mine has 3.73 listed on spid as added, can be seen in post. More confusion for me. See it now- note at bottom. 3.07 ratio used with all 350 engines. So, once 350 is added as option 3.07 is standard and 3.73 is option.
Another add- Yukon gear has a 3.54 ratio and 3.08 for the D44 front as well as others. Expecting some to not agree with me on this, the 3.54 is acceptable to use with a 3.42 rear in off road use. Realistically, probably less than 100 rpm difference between the 3.08 and 3.73 final drive. So why go with odd gears.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 04-06-2023 at 01:35 AM. |
04-06-2023, 06:47 AM | #22 |
I've got this information from the 1971 salesman's price list, for those who need to see printed what I've been saying
04-06-2023, 09:28 AM | #23 | |
https://www.gm.com/content/dam/compa...olet-Truck.pdf (Part of my job for many years was to check these for content and accuracy before they were published). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-06-2023, 11:35 AM | #24 | |||||
I'm going to assume it's a '72 K-10, based on your question (but if not the analysis will be the same): Quote:
Looking at the base content chart in the Info packet I linked (page 6) shows the standard axle as 3.73. Checking the powertrain charts (page 10) shows an optional 3.07 ratio in addition to the standard 3.73, confirming what Richard and Casper posted earlier. So that's not too bad (50/50 odds) but you can't know because you don't know what the original owner chose. Plus open vs posi, so that takes you to one in four odds. Better than I thought it would be, and better than usual. Quote:
Rear axle assemblies proliferate based on series, C vs K (sometimes), locking vs open, rear axle ratio, brake series or friction material (sometimes). So somewhere there is, or was, a chart of 20 or 30 permuations that laid out the various part numbers - and the corresponding code stamp on the axle tube. Any commodity that proliferates like that (rear axle, transmission, engine, shock absorbers, springs, radiators, etc) has a chart like that, or did at one time. You are going to be hard pressed to find that list of part numbers, after 50 or 60 years, and even if you did there's no guarantee that ratio or carrier is still what's inside the axle. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-06-2023 at 01:45 PM. |
04-08-2023, 02:41 AM | #25 |
What I get from the brochure I posted is that 3.73 is standard with a base motor, regardless of trans. When a 350 V8 is added as option 3.08 is standard also regardless of trans. So 3.73 becomes an option as seen on my spid. Do not have the salesman price list special-K has so I cannot comment on further available options. Note that I am referring to a K10, a K20 is different.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 04-08-2023 at 02:48 AM. |
