05-16-2023, 07:17 AM | #1 |
Changed the look
I've had this '70 K/5 for about 6 years now. About all I have done is replace the interior and drive it. I bought it with a 6" BDS lift and 35" MT Baja Claw tires and 3.08 gears.
It rode really rough and bouncy and had a lot of body roll in the turns and would hardly move out of it's own way... I had bought a 2½" Tuff Country EZ ride kit several years ago for another project that never got off the ground. So I decided to install it along with 33" x 12.5 BFG AT tires, 3.73 gears, and a sway bar from a square body truck and changed to Rally wheels for a more classic look The resulting difference is night and day! It drives like a different truck. Before and after pictures.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. Last edited by A1971Blazer; 05-17-2023 at 11:14 AM. |
05-16-2023, 07:41 AM | #2 |
68 C10 Longbed
Re: Changed the look
Love the Ralley wheels
05-16-2023, 08:30 AM | #3 |
Looks great! Those springs are great, but the addition of that anti sway was definitely a good move. It's amazing the difference they make, not just for reducing roll during turns but to stiffen the whole front end.
05-16-2023, 08:39 AM | #4 | |
I took a piece of 2"x4" x 3/16" steel tubing and notched it to fit and slotted the mounting holes for adjustment. Took it on Saturday to get the alignment set and it's good to go, just in time for warm weather!
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
05-16-2023, 11:11 AM | #5 |
I like it. But, then, you've always had a beautiful truck.
When I started rebuilding my Blazer I took the lift off of it and I run 12.5 x 33 BFG all-terrains on it. I also have the rally wheels. The front sway bar is a good idea. I might do that this summer. I'm curious what alignment work you got done. My understanding was that the only thing that's adjustable on these 4WD trucks is the toe-in.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
05-16-2023, 11:20 AM | #6 | |
Correct on the alignment, just had the toe-in set and the steering wheel set straight. I wanted the camber checked and it was well within spec. Although I already had a D44 front disc brake axle, I swapped in a 10 bolt front axle from an '87 Suburban because it already had the 3.73 gear. I put all new ball joints, axle joints, seals, and wheel bearings. I re-geared a spare 12 bolt rear axle that I already had, and I'm saving the set with the 3.08 gears that I removed. I just didn't want to have to do both.
05-16-2023, 12:00 PM | #7 |
I get it. I have 3.73s in mine and I like the ratio. When I'm on the freeway it would be nice to have overdrive, but that's a project for down the road.
05-16-2023, 01:54 PM | #8 | |
Seems like there just ain't enough time....
05-16-2023, 02:42 PM | #9 |
3.73 is a good gear for the TH350.
I run 4.10's because I have overdrive (4l60e). Perfect combo with 33's, IMHO. |
05-16-2023, 08:48 PM | #10 |
Looks awesome! Glad to hear it rides better too.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
05-19-2023, 02:26 PM | #11 |
Carpe manana
New look is really sharp, very nice
05-19-2023, 08:42 PM | #12 |
You did a great job, love the ralleys,,
Things happen for a reason! |
05-19-2023, 11:02 PM | #13 |
Looks Great
Rally Wheels always Touch a Deep spot for me. I like Both (Looks). As we get older / Function rules over Looks for me. The Sway Bar looks Great
05-20-2023, 07:41 AM | #14 |
They look much better at stock height but I am a original freak
05-23-2023, 12:23 PM | #15 |
Very nice, cant go wrong with either wheel in my book!
I am planning the front sway bar as well, probably when I do the ORD springs. |
05-30-2023, 08:57 PM | #16 |
Great looking Blazer and great advice on the front sway bar, now I need one for my K10 as well
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
