04-10-2024, 12:05 AM | #1 |
Radiator question
I have a 1970 GMC 2500. That my parents purchased new in 1970. Five years ago I went completely throught it. It's not a frame off restoration but close.
The engine is a 300 hp 350 SBC crate engine from GM performance. The engine has a small Weiand 142 supercharger, FiTech EFI, original 4 core radiator (great condition) and 700R trans. It's fully bagged with Ridetech 4 link rear suspension. The truck runs great, no issues at all. Engine temps runs between 179⁰ and 183⁰ while driving. Because of the supercharger I can't run a fan clutch. Belt system is serpentine with a 19 inch 6 blade fan and factory fan shroud. The only issue is when stopped in traffic I get a slow increase in engine temp. Temp will keep climbing until I start moving, then immediately the temps will decrease. Before I installed the 6 blade fan and shroud I had duel electric fans with shroud. That did not cool as well as the fan blade and shroud. I've done research here on aluminum radiators but I wondering if going to an aluminum radiator will really help cooling at idle. I really don't want to spend hundreds of dollars on an aluminum radiator and not fix this cooling issue. Who makes a good aluminum radiator that not going to break my bank account. What brand, type, rows, fin count per inch etc. Any info is greatly appreciated. Last photo is how this truck looked in 1970.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
04-10-2024, 09:09 AM | #2 |
Who Changed This?
Re: Radiator question
It is more of an air flow issue at idle, since it cools down when you are moving. I guess you could try a fan with more blades or a higher pitch?
04-10-2024, 09:31 AM | #3 |
It's a heavy duty 19 inxh, 6 blade medal non flex fan. Nothing else available. It's also reverse rotation so what choices there are, are very limited. I can go a larger diameter because of the opening of the fan shroud. The fan moves tons of air wirh lots of fan roar.
04-10-2024, 09:56 AM | #4 |
What does it creep up to? Does it overheat or just gets to say 210 ? All engines will creep up after running at speed and then stopping and idling . If it gets to hot at idle and cools at speed 40 mph or so it’s an airflow problem not a radiator problem . Location of the fan blade can effect the performance to far in or out of the shroud will greatly effect it . The fan blades should be about half way into the shroud . I would start with making sure the shroud is sealed all around the radiator air like water will follow the path of least resistance
Edit: also the head temp may be getting up there but the actual water temp may be much lower . I’ve seen my gauge go to 215+ in the head but the fans don’t kick in because the water temp hasn’t reach 195 the sensor for my fans are in the radiator next to the inlet hose
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 04-10-2024 at 10:03 AM. |
04-10-2024, 04:37 PM | #5 | |
You make a good point about sensor location. The high temp I'm worried about is the head temp. So far 215° has been the highest temp, but the outside temp was only 77°. The radiator inlet temp was just under 200°. What concerns me is the summer time temps here typically approach 120°. Most days temp hover around 115°. So I can imagine this condition will get worse.
04-10-2024, 05:18 PM | #6 | |
My new truck build I’m putting in a Cold case with dual Spal fans with the aluminum shroud that can with the radiator. The fans that came with the radiator just look cheap in my opinion.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
04-10-2024, 07:15 PM | #7 | |
425hp409
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
04-10-2024, 10:03 AM | #8 |
Electric fans put the original electric system into fits unless you up the alternator and rework the battery guage wiring. I put electric fans on my truck but now realize it was not worth the effort. Is it possible the serpantine system you are using is spinning pump and fan too slow? Can you reduce the pulley size on the water pump increasing the pump rotation per engine rpm?
04-10-2024, 04:49 PM | #9 | |
The water pump pulley is the smallest available. Any smaller and the pulley would rub on the water pump housing.
04-11-2024, 11:34 AM | #10 |
These statements tell me its not the radiator; it is an airflow problem: "Engine temps runs between 179⁰ and 183⁰ while driving" & "The only issue is when stopped in traffic I get a slow increase in engine temp". If the radiator was the problem, the temp would also increase at speed.
Looks like your choices are to either trim the shroud back to expose more of the fan, or reinstall and correctly setup those electric fans. If your e-fans were still running at speed, they weren't setup properly.
72 C10 lwb fleetside -stock 350/350 combo |
04-11-2024, 12:45 PM | #11 |
Last summer I solved my idle temp creep. In my case it was an airflow problem. The solution for me was to replace my dual electric fans with spal fans that actually move air. The two 14" fans I had been running were cheap generic 40 dollar fans off eBay that I purchased from Champion radiator with them saying it would cool up to 500 HP or whatever. Those fans were a ripoff. I had my Copper/Brass 4 core original radiator rodded/repaired and with it all back together with the spal fans and a 190 degree thermostat, all is well in summer idling. At speed the temps hover below the the threshold of fan activation (190). At idle the fans will cycle on/off keeping the temps below 200. I have the system wired to activate one of the dual 14" spals and a pusher fan on my condenser whenever the A/C clutch is engaged. Otherwise, one fan activates at 190 and the second activates at 195. Before these changes, I had to turn off the A/C at stop lights sometimes to stop the heat creep. Hth, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
04-11-2024, 08:24 PM | #12 | |
I can drive all day at 40 and up fans never kick in temp may climb going up hill but never go 190 in the head . The water temp would be 10 degrees lower . I do have a Dewitt’s 2 row with 1.25 “ tubes . Also the OP stated the temp went to about 215 max at idle which is pretty much normal for any engine . There’s always a rise it head temp after running and coming to a stop
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 04-11-2024 at 08:35 PM. |
