Stylin
aframe shaft question
i ordered a aframe shaftn when i got it its offset from the ones that i need. the part number came out of the gm book. there was only one part number for it so it couldnt of gotten screwed up heres a pic of what im talkin about. what should i do if i can use it i would like to go ahead n do that, but if i should send it back i will. thanks paul
the pic of what im talkin about is here |
If the new one fits the bushings then it will probably work. Being offset like that you'll need to get it aligned (the front end) as that would surely throw the camber off.
that shaft is designed to give you a little more camber adjustment it should work the same as the original--make sure you rotate the shaft to give you proper camber gain
