No Matter What.
Putting padding inside sub box.
I am going to be building a center console box for 2, 12" subs. When me and my dad were cleaning out the attic we found some not so old padding that goes under house carpet. I think it is 1/2 an inch thick. So I was wondering if it can be glued to the inside sides of the sub box? If so, what affect will it have on the bass? Thanks in advance for any comments.
Currently own: 89 Chevy Silverado Previously Owned:Starting with my first vehicle 86 Mercury Cougar /89 Olds 88 /88 Chevy S-10 /84 Pontiac Firebird(I miss it) /91 Chevy S-10 |
>130dB Moderator
Re: Putting padding inside sub box.
Yes, you can do it. I'm not sure what effect it will have on the sound. Usually you put something along the lines of pillow stuffing inside of a sealed box to aid in sound deadening and tuning.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
Love That '69
AceX is correct. Yes, you can use the padding. Some places put something similar in subwoofer boxes for sound deadening. I dunno if it would tune your subs more or less. But it shouldn't hinder the bass response or SPL of your subs.
I AM CANADIAN!!!!! ![]() 1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights 2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates |
![]() Join Date: Nov 2007
Yes you can and should line the box with a dense material. Make sure when you build you enclosure you brace all panels over say 10" x 14" and don't brace in the middle of the panel, this will help each panel on either side of the brace resonate at different frequencies. the advantage of a loose fill (stuffing) the box is to make the box "appear" larger to the sub(s) ie; more air space.
If you are going to just glue a little on the sides Id just skip it. Most times its used to trick a box thats too small into acting like a bigger box. If you are trying to do this you will want to pack as much into the box as you can. I agree with the above comment that this is only for a sealed box...
as stated sealed box only you can put poly fill (polyester pillow stuffing) inside the enclosure to reduce standing waves in side the box and make the sub think the box is larger than it is! it is very cheap!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
