11-04-2010, 04:59 PM | #1 |
Why a 2 piece driveshaft?
Does anyone know why the 1967 - 1972 Chevrolet C10 had a 2 piece drive shaft? I am replacing mine with mixed results. Advanced Auto Parts shows one picture and has a different part in the box. Auto Zone doesn't have it and NAPA was more expensive. I'm waiting to see what O'Reilly has for me now. That made me wonder why it's 2 pieces. I've had other cars and trucks that had drive shafts that long and there was no center support bearing.
11-04-2010, 05:06 PM | #2 |
Big Red - Now its a SWB!
Re: Why a 2 piece driveshaft?
It's a general rule that if the driveshaft is more that 72" then it needs to be two piece or it won't balance right.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
11-04-2010, 05:53 PM | #3 | |
As a drive line gets longer the critical speed goes down you can increase the critical speed by using a larger, thicker tube or both. Critical speed is the point where the drive-shafts rpm's match the frequency of the material and begins to bend off its centerline.
Good reading here>>> http://www2.dana.com/pdf/J3311-1-DSSP.pdf Ujoint listings here w/dimensions>>>http://www2.dana.com/pdf/K350-1-DSSP.pdf
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
11-04-2010, 06:25 PM | #4 |
So there..
J.
1972 Custom Deluxe Highlander C20 1971 Javelin SST New Project 1971 Demon 340 1969 SS El Camino 1968 SS RS 396 Camaro 1967 Barracuda Formula S 1965 140/4sp Corvair Monza Convertible Sorry, but I don't do Fords. |
11-04-2010, 06:29 PM | #5 |
if u need a new drive shaft find a reptual shop and have it built
11-04-2010, 07:00 PM | #6 |
Old Skool Club
Could it be that the leaf-spring chassis had a one-piece and the coil-spring chassis had a two-piece? I'm just asking and have no clue. My '96 GMC has leafs and a one-piece. My '69 has coils and a 2-piece. As long as the u-joints are good and properly installed and the center bearing is also good and the rubber in it is good, what is the problem?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
11-04-2010, 07:04 PM | #7 |
short or longbed 2-piece..they had those too..
If you need a shortbed driveshaft one piece to replace the 2 piece, you simply get a driveshaft out of a mid 80's 4door caprece...Its a bolt in..and easy to find.. |
11-04-2010, 09:27 PM | #8 | |
And what is the length of it? do you know it off hand?
Ben Its a 67 Chevy C10 now, and its short now too. Here is my 1967 Chevy C10 Shortened Build Blog http://boyescustoms.blogspot.com Here is my 1967 Chevy C10 Shortened Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=433535 Last edited by mr.chevy; 11-04-2010 at 09:28 PM. |
11-05-2010, 09:55 AM | #9 | |
the later 86-up are 55 inches weld to weld When you get your truck back together,take your old one,slide it in the trans where the yoke normally rides,then just measure it..and go to the yard and pick one out. That way you know..I worked at a big yard years ago..and you found what worked.. |
11-06-2010, 11:02 AM | #10 |
Mr. Chevy (or anyone), let me know what you find out. I'm in the same predicament. I just converted my long bed coild spring chasis C-10 to a short bed. I'm planing to keep everything else original 250 6 Cyl, 3 manual trans. But I need to resolve the driveshaft issue. My plan was to look in a bone yard for a one-piece driveshaft from a 67-72 6cyl, three on the tree tranny. Any suggestions? My other option was to have one custom built...suggestions?
11-04-2010, 09:50 PM | #11 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
11-04-2010, 10:09 PM | #12 |
Old Skool Club
When I made my comment, I meant for it to say that I didn't know and was just making a comment. I have no proof. My SWB has a small block and a TH400, as well as a 2-piece driveshaft.
I can see why longer wheelbase vehicles have multiple section driveshafts, so the mystery has been the subject of this post.
11-04-2010, 07:09 PM | #13 |
My 68 GMC is leaf and it has a 2 pc shaft.
11-04-2010, 09:46 PM | #14 | |
Sierra Grande Club
11-05-2010, 10:06 AM | #15 |
Mine is a short bed flare side with a 2 piece shaft. I had a 1976 Ford with a 8 foot bed and it had a one piece shaft. The length thing makes no sense. All of the older cars that were huge had one piece shafts with or without coil springs. Think of the old Buicks, Olds and Packards. My shaft is fine. I'm changed transmissions and now I'm replacing the u joints and center bearing. My last truck was a '68 long bed and sent from a 3 speed manual to a TH350 and we kept the same driveshaft.
11-05-2010, 12:57 PM | #16 | |
11-05-2010, 01:12 PM | #17 |
Actually, quite a few GM cars began using 2 piece shafts as far back as the late 50s. This wasn't done because of shaft length or loading, but rather to allow a lower floor hump or accommodate an X-frame. Other makes may have done this too, but I happen to be personally more familiar with GM.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-08-2010, 10:27 PM | #18 |
My 95 V6 Camaro HAD a two piece drive shaft. Found out nobody but GM carried it and the price tag was $900 so I bought a one piece and have had no problems.
2006 Silverado 2500 HD |
11-05-2010, 01:43 PM | #19 | ||
11-05-2010, 02:25 PM | #20 | |
Makes me think of a joke: this engineer takes his tire into the Goodyear store to get it balanced. While he's watching the work get done (...because we always have to watch to make sure it's done right -lol) the young tire tech takes the weight displayed and splits it in two, putting half on the outboard face of the rim and the other half on the inboard face of the rim. He asks the engineer: "do you know why I did that?" The engineer clears his throat and says, "why, yes, in fact I do. If you were to put all the weight on one side, the offset of the wheel introduces a moment, the resulting force being proportional to the lateral distance of the offset and increasing with vehicle speed. The resulting magnitude can create a disturbance which can magnify, particularly at it's resonant frequency and be felt in the car at certain speeds, generating customer pleasability issues, erratic tire wear and/or durability concerns". The kid looks blankly at the engineer and says "yeah. Cause if I don't it'll wobble". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-05-2010 at 02:34 PM. |
11-05-2010, 03:21 PM | #21 |
I had always thougth it was also a clearance issue. The 2-pc has the primary shaft level to the chassis and the secondary tilts downward to the rear axle. This set up would have more clearance than a 1-pc shaft that tilts downward from the tranny to the rear axle. If the wheelbase is small enough the difference in clearance is negligible, but as the wheel base increases it becomes a ground clearance issue with the driveshaft. Aside from what has been mentioned in previous posts. I could be wrong, it wouldn't be the first time.
Just my $0.02 Dano
'69 Fleet It ain't yours, if you didn't build it! |
11-05-2010, 10:23 AM | #22 |
They all came from the factory with a two piece driveshaft, long bed or short bed. If they have a one piece driveshaft, it's been converted.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
11-05-2010, 10:55 AM | #23 |
to answer your question, I like my 2-piece because it doesn't have the same vibrations that every single 1-piece in my lowered trucks has.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
11-05-2010, 10:57 AM | #24 |
The "critical speed" post is correct.
What you guys might be missing is that propshaft critical speed not just based on wheelbase but is also based on trans type (length), rear axle ratio, tire size, and engine type (larger engines allowing a higher top speed). So - a long wheelbase truck with a low (numerical) rear axle ratio spins the shaft slower and might get a one piece, but an otherwise comparable truck with a high rear axle ratio might get a two piece. One other comment - critical speed is not directly related to balance, but rigidity. When the shaft exceeds it's critical speed it begins to bow in the middle and swing like a jump rope. Hence the disturbance and durability concerns. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-05-2010 at 02:35 PM. |
11-05-2010, 11:06 AM | #25 |
I guess I'll accept that. It just seems odd that some longer vehicles have one piece and a shorter C10 has a two piece. Perhaps it's due to the diameter of the drive shaft itself.
