09-30-2022, 02:54 PM | #1 |
Clutch Mystery
Buckle up and put on your thinking caps. This is tooooo weird!
My truck is a 1968 GMC cab and vin on a 1972 3/4 ton FWD frame, stick shift. The motor was recently replaced with a 1999 350 Vortex by a very competent guy who has probably done 1000 R&R's over the years. Starting Sequence: 1. Put the tranny in neutral 2. Turn the key, engine starts and runs smoothly. 3. Depress the clutch Pedal. 4. Engine dies. There is no neutral safety switch on this vehicle. I have looked for vulnerable loose wires that could be pinched by the pedal and linkage and have found none. The engine does not seem to be "loading" it just dies. Other symptoms: If I put rearward pressure on the stick and depress the clutch pedal half way, the tranny slides into gear. If I then continue to depress the clutch pedal fully, the engine dies. In other words, depressing the pedal ALL the way triggers the engine to die. Comment: This feels and sounds like an electrical issue but as I said, I've searched for loose wires and found none. Any ideas for me? ccstelmo |
09-30-2022, 03:06 PM | #2 |
Re: Clutch Mystery
New engine and the old transmission?
I think there is a bellhousing, clutch or clutch fork misalignment problem. Which unfortunately means the transmission is going to have to come out in order to identify what is binding up. Did you drive the truck home from the shop?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-30-2022, 04:06 PM | #3 |
Re: Clutch Mystery
HO455:
I forgot to mention that. I drove the truck home 115 miles. I've had it on and off the dirt roads around here, in and out of 4WD, for a few weeks without having this problem. It started suddenly after I had been using the electric winch to pull a couple of stumps. ccstelmo |
09-30-2022, 08:27 PM | #4 | |
Re: Clutch Mystery
09-30-2022, 08:31 PM | #5 |
Re: Clutch Mystery
I will try that. I'll be out of town for several days and will get back to you when I do.
ccstelmo |
10-01-2022, 02:11 PM | #6 | |
Re: Clutch Mystery
I would also inspect the motor mounts, one may have failed. Oh and Welcome aboard!
10-01-2022, 08:12 AM | #7 |
Re: Clutch Mystery
The winch shouldn't really make a difference on the engine running unless some real strange wiring was done. I would check for a wire that grounds out when the pedal is depressed. Its pretty easy to get one that gets chafed.
10-01-2022, 09:47 AM | #8 |
Re: Clutch Mystery
Are the ground straps, from the firewall to the valve covers, still attached?
I would run a wire from the + side of the coil to a bulb and install it where I could observe the bulb from the drives seat. Ground the bulb to a ground on the firewall and see what happens to the circuit when the clutch is pushed in. Then do the same thing with the ground on the motor. Seems the grounds should be fine because the starter works but need to start somewhere. One has to assume your have compression and fuel. That only leave electrical. I would also pull the engine harness plug from the fire wall and confirm it's copper terminals are in pristine condition. Yup that's a good one! Cheers |
10-01-2022, 09:51 AM | #9 |
Re: Clutch Mystery
90% of electrical problems are grounding issues.
10-02-2022, 12:54 AM | #10 |
All about them K’s
Re: Clutch Mystery
Did you keep all of the fuel injection or put a carb manifold on the vortec?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
