Old 01-28-2014, 01:15 AM   #1
67Steven
67Steven's Avatar
6L80 transmission whine at shut-off
I have what I believe to be an issue with my transmission. When I shut the motor off, the trans produces a high pitched whine.
It is a 2008 L92/6L80 combo out of a hummer with 13K miles. Both components are from the same truck, as is the harness.
I have done a multitude of searches, and I have discovered that this is supposed to be normal- it is the solenoids 'equalizing' pressure and it should shut off after a minute or two.
My transmission whines for hours if I let it, even overnight as I once found. No codes have been thrown, and it seems to work okay, although I have only moved it down the driveway and back a couple of times. The whine stops as soon as I interrupt power either by the ground cable or the trans plug, and stays off until I turn the key on.
Anyone else have or had this problem or know what it might be? Again, any help is appreciated!
67Steven is offline   Reply With Quote
Old 01-28-2014, 02:25 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 6L80 transmission whine at shut-off
Have you hooked it up to HPT or a pro-style scanner that can read/command trans codes?
Any chance your harness is pinned-out wrong and one of the solenoids is getting a signal it shouldn't?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-28-2014, 09:07 AM   #3
67Steven
67Steven's Avatar
I do not have access to one of those readers, but I guess I can try to locate a mechanic with one to try that out.
As far as wiring, it is the original harness, and nothing was changed at the transmission, so I am going to speculate that it is okay. I am just worried I will need to replace the solenoid pack/TCM unit.
Old 01-30-2014, 08:40 PM   #4
clinebarger
The TCM is staying "Awake" for some reason, Most likely a wiring error,
There is a Pink Ignition Hot wire at the Trans plug, This wire should only have power with the key on.
Don't replace the TCM!!!!
clinebarger is offline   Reply With Quote
Old 02-03-2014, 08:44 PM   #5
67Steven
67Steven's Avatar
Sweet! I will check the wiring to see if it is staying on, well verify that is the issue. I have a relay from the ECM that turns the trans on and off, and I can hear it click that off, but I guess I have something incorrect.
I will update when I figure it out.
Old 01-28-2014, 04:25 PM   #6
Houston Ben
Houston Ben's Avatar
My 6l80e has a high whine in 1st but that's it
Houston Ben is offline   Reply With Quote
Old 07-17-2014, 11:59 PM   #7
Chvy2NV
Any updates?
Chvy2NV is offline   Reply With Quote
