03-09-2016, 03:34 PM | #1 |
Plan for 5.3 build
I want some opinion on my build. I have been all over the internet planning and there is so much mixed information I just want to be sure I get this right so I am happy with the end result. This will be for a 5.3/4l60e combo in a 74' C10.
Stock bottom end 243 heads milled .030 stock L33 head gaskets (.051) TSP 224R 112LS Stock truck manifold 2800 stall Does that seem like it will be a good performer. I want something with some power but don't want to get too extreme. I want to keep good street and highway manners. Thanks for any help!
If you live in Oklahoma click this link |
03-09-2016, 03:50 PM | #2 |
Re: Plan for 5.3 build
Do you mean stock truck intake manifold? or exhaust manifolds?
If you mean intake that is fine the truck intakes flow quite well. If you mean exhaust manifolds, I would consider headers instead. They will be worth decent power with a cam and 243 heads. If you have an older lower performance 5.3 with dished pistons then milling .030 off the 243 heads will put compression back to stock levels. On a newer/HO 5.3 with flat top pistons milling the heads .030 will give a nice compression bump. Over all it should be a pretty decent performer with any of the above possibilities. |
03-09-2016, 04:22 PM | #3 |
I was talking stock intake manifold.
They are dished pistons. I was trying to get compression to about 10:1
03-09-2016, 04:38 PM | #4 |
Also, TSP is recommending a 2800rpm stall for the 224R cam but everything else I find online (forums) people are recommending a 3600 rpm stall. pretty big difference there...
03-09-2016, 05:25 PM | #5 |
Boosted Member
IMO, a 2800 stall isn't worth the expense. You won't feel it over stock. Hell, my Circle D 3200 feels stock to me. It's not loose at all...but that's what I need at my power level...I'd blow thru a loose converter.
3400-3600 with a good cooler would be my choice for your setup, assuming it's a play truck, and doesn't work to hard.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
03-23-2016, 11:20 AM | #6 | |
I remember you as "compressor surge" I believe from back in the central Illinois domestics days. |
03-28-2016, 10:18 AM | #7 | |
Boosted Member
According to my invoice, i have the "4L80 LS Pro Series Stage III 258mm 2B" from Circle D.
