Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 07-27-2011, 11:05 PM   #1
Meatman
Meatman's Avatar
Rust Repair
Did some rust repair today. Figured I would post up pics and share my shady body work skills.
Cut out the bad spots last nite so I could clean up underneath and hit everything with POR15 and it could dry over nite. I really should have replaced whole cab corner from door back because there was alot of rust on the back side and metal was kinda thin, but that was way more more then I wanted to tackle at this point in time. Cleaned inside the best I could and caked on the POR15.
Daily-94 K2500 350 5spd extended cab longbox
Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack.
Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881
My 01 TA and 88 Formula hide in the garage. :-)
Meatman is offline   Reply With Quote
Old 07-27-2011, 11:07 PM   #2
Meatman
Meatman's Avatar
Re: Rust Repair
Got up at 6 am to try to beat the 105 degree weather. Cut out new patch panels and got them to fit best I could.
Old 07-27-2011, 11:12 PM   #3
Meatman
Meatman's Avatar
Re: Rust Repair
Then it got kinda sketchy. I just have a cheapy Northern Tools flux core 2 setting welder. First time Ive used it on sheet metal. It did ok, but took alot of grinding to clean everything up. Metal was really from rust on the back side on drivers side and it just kept blowing through. You can see alot of the holes in first pic. Took some work but I got them all filled.
Drivers
Passenger side went way better.
Old 07-27-2011, 11:14 PM   #4
Meatman
Meatman's Avatar
Re: Rust Repair
Sanded alot, then shot some primer. Sanded more then caked on the body filler to hide all my sloppy welding.
Old 07-27-2011, 11:18 PM   #5
Meatman
Meatman's Avatar
Re: Rust Repair
Heres final product with some high fill and just some flat black for now. Next week truck will get bedliner on the lower rockers and fender flares. Came out ok. Could use another round of sanding and filler but the bed liner will hide all the imperfections. Ought to last a few years. I will add pictures next week of the bed liner painting too.
Old 07-28-2011, 12:20 PM   #6
benoit454
Chris
benoit454's Avatar
Re: Rust Repair
I wouldn't call it shady, I'd call it done right. You cut out the old stuff, cut a replacement panel to fit, welded it in and ground down, body worked, same as body shops man good work.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-28-2011, 08:22 PM   #7
76/85 Truck
76/85 Truck's Avatar
Re: Rust Repair
Great job!! Looks awesome!
Rich
My first truck!! 1976 Chevy 3/4 ton Camper Special and a 1985 GMC body. Has a 350, 4 BBL Edelbrock, with a Turbo 350, and NP205 T-case.
76/85 Truck is offline   Reply With Quote
Old 07-28-2011, 08:49 PM   #8
chris@bigjranch.com
KIDHLR
chris@bigjranch.com's Avatar
Re: Rust Repair
Thanks for posting, it's fun to watch somebody else work on their truck! Looks like you did a fine job.
Christopher Johnson
Project - Grafted In AKA the "KIDHLR"
Conversion - KIDHLR Meets LPG
KIDHLR 2.0 Rise of the diesel(a 6.5 powered 6 Door pickup)
Romans 11:17-22
"Branches were broken off so that I could be grafted in"
chris@bigjranch.com is offline   Reply With Quote
Old 07-29-2011, 03:01 AM   #9
collins10672
collins10672's Avatar
Re: Rust Repair
i think you did a fine job.looks great.
collins10672 is offline   Reply With Quote
Old 08-30-2011, 05:31 PM   #10
lax54650
Re: Rust Repair
nothing wrong with that
lax54650 is offline   Reply With Quote
