Junior Member
![]() Join Date: Feb 2019
736J paint code and 431XF trim code
Hey guys,
I just got a 1960 half ton long fleet. I’ve searched but can’t find what these codes are. The truck has been repainted about a million years ago but if they went with the stock colors it looks like white and tartan torquoise, but that isn’t 736J. And I can’t find 431xf either. The truck appears to have come with the custom comfort option and it also had the funky side trim and rear cab chrome and sail panels. Anyone know what these codes are? Thanks! |
![]() ![]() ![]() Join Date: Jan 2018
Re: 736J paint code and 431XF trim code
Maybe it's a special order code for a fleet order or something?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Junior Member
Ok I found something saying that 736J is brigade blue and Bombay ivory, which looks right. I still can’t find 431xf though.
![]() ![]() Join Date: Apr 2012
431 is "Custom Cab" which in this case means , Custom Seat and Left Door lock , info is in the 1960 Data book and specific to 431 option code.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Junior Member
Ah that makes sense. It does indeed have all that stuff.
Thanks guys! |
