06-13-2006, 08:35 AM | #1 |
Junior Member
Gauge needle paint
Does anyone know were I can get the correct color of paint for my gauge needles? I bought some Acrylic all purpose orange but it's too light, any suggestions?
Clif '68 C/10 LWB, 327, TH400, 12 bolt Last edited by clif1968; 06-13-2006 at 08:35 AM. |
06-13-2006, 08:39 AM | #2 |
Re: Gauge needle paint
a good model shop will have testors dayglo orange
06-13-2006, 08:46 AM | #3 |
I used the flourescent orange from a spray can and it matches realy well.
06-13-2006, 01:02 PM | #4 |
I bought a can of Krylon "red glowing orange fluorescent" (part #3101)at the local NAPA store, and it matches perfect.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
06-13-2006, 10:41 PM | #5 |
Junior Member
Those look great byrd!
HuggerCST, if it's not a problem could you post a pic of your guages for me?
Clif '68 C/10 LWB, 327, TH400, 12 bolt Last edited by clif1968; 06-13-2006 at 10:43 PM. |
06-14-2006, 01:27 PM | #6 | |
06-15-2006, 01:06 AM | #7 | |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
06-13-2006, 01:46 PM | #8 |
PROJECT 7DEUCE
Testor orange works really well..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-13-2006, 03:03 PM | #9 |
i used dupli color high temp chevy engine orange, matches the engine now. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
06-13-2006, 07:56 PM | #10 | |||
Union Electrician
model master flourescent red Part# FS 28915 is what I have used for years. It is the closest I have found to the stock color.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
06-13-2006, 08:01 PM | #11 |
Junior Member
Thanks for the replies. I bought a can of Krylon #3101. It's got to look better that what I used.
Clif '68 C/10 LWB, 327, TH400, 12 bolt |
06-14-2006, 02:22 AM | #12 | |
Respectfully
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! Last edited by longhorn70gmc; 06-14-2006 at 02:24 AM. |
06-14-2006, 09:52 AM | #13 |
Junior Member
I live in a small, small town options are limited to napa, oreillys, and ace hardware. Wal-mart is 35 miles, one way. I'm pretty much limited to ordering off the net.
Clif '68 C/10 LWB, 327, TH400, 12 bolt Last edited by clif1968; 06-14-2006 at 09:52 AM. |
06-13-2006, 09:19 PM | #14 | |||
Union Electrician
here is a couple of pics of the model master color...
06-14-2006, 03:59 PM | #15 | |||
Union Electrician
clif goole for model paint and you can find it on the net. 86swb a fellow member I found a link to it for him and maybe he will see this thread and speak up. Meantime if I find it I'll post it.
06-14-2006, 04:29 PM | #16 |
Junior Member
Thanks for the help guys. I found it here, http://testors.com/catalog_item.asp?itemNbr=786. I went ahead and ordered it. Small towns are great till you need something, even worse after living in the OKC area for 32 years and anything you need/want is less than 1 mile away.
06-14-2006, 06:13 PM | #17 |
Here are some pics of a couple that I did for myself. They are dusty, and I have a cheap camera, but hopefully you can see the color. The dash without the woodgrain has a aftermarket tach, and the needle has not been repainted on it, but it matches very well. On the first one that I built, I used model paint from Walmart, and mixed two colors to get the color that I wanted, and brush painted them. It came out ok, but it was glossy, and the needles faded pretty quick. The Krylon is semi-gloss, and looks alot better than my brush paint looked. I don't know how bad it fades yet. It is alot easier, and quicker to spray them in my opinion. I simply cut a slit in a piece of paper, and slide it under the needle, and around the shaft. Then I take another piece and slide it in the opposite direction to mask the gauge face. Put 2-3 coats on and you're done. The tach center is another story, lol. Hey byrd, what's the secret to getting those lenses so slick?
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com Last edited by HuggerCST; 06-14-2006 at 06:15 PM. |
06-14-2006, 06:51 PM | #18 | |||
Union Electrician
Good eye hugger, that is a factory original lens in the tach dash pic I posted, I can't take the credit for it I pay a fellew member to polish them up for me to use.Lamar is his user name on here and his name as well. He makes them look like glass and says just uses a buffing wheel on a bench grinder with some polishing compund(I don't know what he uses) and says it only takes him about 15-30 minutes to do each one. They are much nicer than the repops, but in direct sunlight there is a few lines that are not very noticable, however the factory lenses seem to be more scratch resistant than the repops, and all of them will have some scratches anyway from normal cleaning of the lens.
06-14-2006, 06:56 PM | #19 | |||
Union Electrician
Hugger I'm sure the lenses in the pics you posted look better than in the pics, that flash does some really weird things, the needles look like they match up really well and the dashes them selves look really nice. Next time might iI suggest, you use some scotch(clear household tape) tape and mask off the hot mark on the temp gauge to paint it the same color as the needles,(remove tape while the paint is still wet and then set the dash up so that the paint won't run) one easy and minor thing that make a big impact on the overall look of the dash....Randy
06-14-2006, 07:02 PM | #20 | |||
Union Electrician
clif that is it and very easy to use, just brush it on with two or three very light coats and you will be very pleased with the outcome. Remember to clean the needles good with a small detail brush to remove any loose dirt or debris from the needles prior to paint them.
06-15-2006, 12:15 AM | #21 |
Junior Member
Thanks for the pics HuggerCST. Man, it's really hard to tell the difference between the krylon and the model master. I think I'll wait till the model master paint gets here and compare it with the krylon side by side before I do anything. Thanks alot for the help guys it is very much appreciated.
Clif '68 C/10 LWB, 327, TH400, 12 bolt Last edited by clif1968; 06-15-2006 at 12:24 AM. |
06-15-2006, 01:17 AM | #22 |
God Bless Mr. T
67 c-30,
How did you get your panel so shiney? Did you strip it down and paint it or did you buy it that way?
Like a midget at a urinal...sometimes you must stay on your toes. |
06-15-2006, 08:23 AM | #23 |
It is a new chrome bezel that I bought at Super Chevy in Commerce, GA.
