07-29-2012, 07:38 PM | #1 |
Clutch fan?
My clutch fan sounds real noisey when i take off.Almost like a big rig.Is this a sign that it is going out?I have no over heating issues.
07-30-2012, 11:33 AM | #2 |
BAD BOW-Silverado XST
Re: Clutch fan?
Nope. It's fine. When you idle, temps goes up so the clutch engages. If it does not stop at all speeds or after a few minutes of driving, then you should replace it. Next time it's hot, turn off the motor. Spin the fan by hand. It should spin freely. If you have to force it or it does not spin freely, it's starting to fail.
I ditched the stock fan for a 4.0 Explorer fan. It's lighter and has more fins on it. It's also more efficient. I noticed the difference with the A/C at idle and slow speeds. Follow my swap here: |
08-07-2012, 01:04 AM | #3 | |
Rollin' Old Skool
Re: Clutch fan?
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
07-30-2012, 08:36 PM | #4 |
Re: Clutch fan?
Thanks gchemist.The fan does go off after a few minutes.This is the the frst vehicle ive owned that had a clutch fan.Thank for telling me about the ford fan swap.
08-07-2012, 08:39 AM | #5 |
Re: Clutch fan?
Read about my conversion here: http://67-72chevytrucks.com/vboard/s...d.php?t=409153
