03-21-2002, 11:04 PM | #1 |
blazer ???
Does the blazer rear seat sit exactly over the rear axel in between the tubs?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
03-21-2002, 11:06 PM | #2 |
basically, thats where the underfloor flat brace deal is that is for the mounting of the seat, i remember that much form when i tore up the 72 blazer tub
03-22-2002, 12:07 PM | #3 |
SKINNY TIRES RULE!
There are metal brackets in the floor where it bolts down. If you have one you could look at, that would show you where the seat sits. Someone had photos from cleaning up the bed that shows the brackets. I believe it is right between the wheel tubs.
------------------ '69 K-5 Blazer - 350/TH350, 6" lift, 35" tires Bothell, WA
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
03-22-2002, 03:06 PM | #4 |
On the underside of the bed, there should be some encased nuts for the seat brackets. At least mine did, and yes, it sits right between the wheel-wells.
1998 k1500 xcab Had: 1972 blazer4x4, 350/350, factory a/c |
