big block lift kits?
I have searched all over this forum as well as calling multiple vendors. I can not seem to find what i need. Looking for a 4" all spring lift kit for a big block pickup. If anyone can point me in the right direction it would be much appreciated.
'71 Chevy 2wd long box~ Sold '70 Gmc 2wd long box~ Sold, Finally convinced owner to let me have it back haha '72 Chevy 4wd long box~ keeper ![]() |
Grease Monkey
Re: big block lift kits?
Suspension lift kits are not specified by motor, only 1/2t, 3/4t, and 1ton. There is only 150-200b difference between a SBC and a BBC. Thats an extra passenger. It won't effect the suspension.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
![]() Join Date: May 2003
4x4's didn't come from the factory with big blocks, so you won't find and springs advertised that way. But you can find springs with a heaver ratings than others, and there are companies that you can custom order. !
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Thank you for the reply. I looked at the tuff country lifts and they are telling me that the spring rate is too soft for big block applications. I wanted to be sure so the truck will sit level. I will save on weight with the aluminum heads anyway. Thanks again
Grease Monkey
If you go with a 3/4 ton spring.
http://www.sdtrucksprings.com/index....oducts_id=2348
This is what i was looking at. According to them thats with their "heavy duty" front springs.
Talk to http://offroaddesign.com/index.htm they don't have your tuck listed but can get you a lift for it no problem.
Andrew, I appreciate it. I'll give them a call.
I was wrong they do have your truck listed http://offroaddesign.com/catalog/TuffCountry.htm Or you could do a shackle flip and switch in the rear that will give you 4 to 4 and a half inch lift in the rear with your stock springs http://diy4x.com/product.php?product...cat=250&page=3
