07-18-2018, 09:09 AM | #1 |
LED Headlight Conversion
Have any of you converted the headlights and top parking lights to LED? My lights have a lot of draw on the battery and I would like to convert to LED. Please let me know if you have any links or part numbers. Thanks!
07-18-2018, 09:42 AM | #2 |
Re: LED Headlight Conversion
The only good options for LED are JW Speaker and Trucklite. The cheaper ebay/amazon/lmc lights have a horrible beam pattern; you won't be able to see well and they'll blind oncoming traffic.
https://www.amazon.com/J-W-Speakers-...+speaker+evo+2 https://www.amazon.com/Truck-Lite-27...=trucklite+led If you don't want to spend that much on lights, Cibie H4's with a relay harness are the best H4 headlight available. The relay harness with take the load off the factory wiring and switch, and the headlights dont' see any voltage drop so they're brighter. https://www.amazon.com/Cibie-082440-...words=cibie+h4
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
07-18-2018, 10:53 AM | #3 | |
This is just not close to the truth, sorry. Dapper 575's have a tightly controlled beam pattern and are completely "aim-able" My vision is now out to over 1,000 feet. here is the install posts I did. http://67-72chevytrucks.com/vboard/s...hlight=LED%27s |
07-18-2018, 11:07 AM | #4 | |
I had a set of Dapper 7" V2 HID's in my Miata, ended up going back to Cibie H4's because they perform soooo much better. Dapper uses small H1 halogen projectors with re-based HID bulbs, so the optics aren't designed for the HID bulb. The beam pattern was only 90* wide, not at all adequate. They also include instructions on how to bend the three prongs on the base if the bulbs to center the hot spot with the middle of the cut off... the end user should not have to adjust the bulb's placement inside the reflector! Very poor quality control. The cut-off was clean and sharp, but there's way more to a "tightly controlled beam pattern" than having a good cutoff. The fact that they offer a halogen, HID, and LED bulb with the same projector shows that they don't really care about the beam pattern...
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 07-18-2018 at 11:14 AM. |
07-18-2018, 11:33 AM | #5 | |
Geesh. The guy asked about LED's not HID's You keep posting about your one bad experience with a HID project you had on your little Import. You have no experience at all with modern focuse beam LED head lights so kindly shut the heck up. You trashed my original thread about a positive experience I had with a company that has some of the absolute finest customer support and deserve to be considered by any of us. If anyone wants advice on sealed beam upgrades, you are the guy. |
07-18-2018, 12:56 PM | #6 | |
So when you recommend dapper's LED headlights you're really recommending a set of halogen projectors with LED bulbs.
07-18-2018, 11:31 AM | #7 | |
07-18-2018, 10:33 AM | #8 |
I have the fan cooled LED's headlights with halo's From Dapper Lighting. https://www.dapperlighting.com/
They are very, very bright and put out a pure white light. Spendy, but very nice. Last edited by Robert Haas; 07-18-2018 at 10:55 AM. |
07-18-2018, 10:39 AM | #9 |
Some more
This is the day time running light mode where just the Halo's are on. The outside halo turns amber and flashes with the turn signals or flasher circuit. |
07-18-2018, 10:59 AM | #10 |
Thank you for the great replies. The Trucklite 27 and Dapper 575's look really nice.
I was thinking about getting a pair of these https://www.amazon.com/Incandescent-...6DYRSCB36N9D1F Just to keep cost down a little. Any thoughts on those? Or am I in for a big expense to convert to LED? |
07-18-2018, 11:12 AM | #11 | |
Those aren't even headlights, they're flood pattern work lights for a tractor. The Par36 size is smaller than a 5.75" headlights so they won't fit in your headlight buckets. The two links I first posted are the best legitimate DOT LED headlights that perform safely at night. 99% of everything else sold as "LED headlights" are going to be inferior to a good pair of sealed beams and a relay harness.
07-18-2018, 11:16 AM | #12 |
Here's a shot of the beam pattern of the Dapper V2's. Very narrow, and way too much foreground illumination.
07-18-2018, 11:38 AM | #13 |
https://www.octanelighting.com/produ...g5-led-6k-7x63 These are just bulbs to put in your H4 headlight housing. I have no idea how good they are or if they will even fit in the trucks headlight bucket. They seem pretty long.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
07-18-2018, 11:46 AM | #14 |
Never Ending Projects
Keep things civil guys. Opinions are like.... well you get the idea. Keep things on topic. Asking about LED lights is not asking about HID's. Please don't intermingle these different lights in your replies folks.
As for LED recommendations, though this was for my Jeep Cherokee (square lights), I bought a cheaper set of LED's off Amazon that had gotten a lot of good reviews. Had them in one night and sent them back. Pattern was horrible. Yes they were "bright and white" but not much better then stock pattern. Spent the $$$ for a set of J.W. Speaker 8700 Evo 2 (you want the Evo 2 as they are brighter then the original ones). OMG! These were better then my factory LED lights in our '16 RAV4, which has been the best lighting of any of the 55 vehicles I have owned. It wasn't cheap but I love to drive at night and it kept me from needing any other extra lighting (fogs, driving, etc.) My .02 worth.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-18-2018, 01:16 PM | #15 | |
07-18-2018, 12:29 PM | #16 |
Moderator
Don't be hatin.
Besides is Then vice Than.
07-18-2018, 04:50 PM | #17 |
Well there it is.
I do not expect John to reverse his position nor to offer an apology for misrepresenting a product he was wrong about.(something a grown up would do) I will be stunned. He flat trashed the thread I created after installing the 575's from Dapper and it really pissed me off. Nothing I can do about it now, well there is one thing. I will be installing the exact same set up in the truck we are building out in the shop and will promote Dapper to anyone that bothers to read about it in our build thread. I am not an employee or paid a thing for my support, I paid full price for the last set and will pay full price for the next. That is how I stand behind any product I use on our builds. |
07-18-2018, 08:23 PM | #18 |
That reads like a person that is too proud to say sorry without wrapping it up in 2 paragraphs of justification.
Way to own it. |
07-19-2018, 08:50 AM | #19 |
To the O.P., I have the Trucklites on mine and I really like them.
07-19-2018, 10:49 AM | #20 |
meowMEOWmeowMEOW
Since we're having the conversation; JW Speaker lights for Humvee and Oshkosh trucks.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
07-19-2018, 11:24 AM | #21 |
Seems like it is going to be an expensive upgrade. These have decent reviews: https://www.amazon.com/gp/product/B0...QAOP89XC&psc=1
But I would rather have lights with clear glass color since I have a chrome grill and not a painted grill. |
07-19-2018, 06:09 PM | #22 |
I have a set of truck lite LED's on my old MR2, and a set of Morimoto Sealed7's on my truck. I've used a number of Morimoto products in the past and have always been pleased with the quality and longevity of them.
I actually don't care for the truck lites. They are bright, and will be staying on my MR2, but they have a horrible hotspot in the middle which really annoys me. Beyond that, they are fantastic, bright, wide and far. The Moritmoto's are LED projectors and are much more evenly lit. They shine wider, further and are very comparable to the output of my 2015 Mercedes. I bought the 1.0 series a few months ago when they were on sale for $150/set, looks like now they just carry the 2.0 for $600/set. IMO, worth the extra over the truck lites, but they have a look that doesn't suite all classics as well. All that being said, if you aren't concerned about getting much better light output than stock, you'd be fine with nearly any 7" LED light. I'd wager that even the cheap sets on Amazon will shine as well as the stock lights on these trucks and draw less power. If you want a better output and the low amp draw of LED's, be prepared to pay up. |
07-20-2018, 10:52 AM | #23 |
Thanks everyone for the info. I am happy enough with the light output of the factory lights. The problem is when the lights are on, the cooling fan is on, and the A/C is on, there is a big drain on the system. The lights seemed like the easiest thing to modify to ease the load. I'm hoping to find some LED's that won't break the bank.
07-20-2018, 04:33 PM | #24 | |
07-20-2018, 05:11 PM | #25 |
I sure wish they would outlaw Led lights , I know they the new thing but man when you are driving the other way they hurt... If your are in your work car at 4:00 am in the rain. The new Ford trucks are BAD Wow!
Maybe I am old? |
