09-02-2018, 06:45 PM | #1 |
K10 rear U-bolt
In my 61 K10 the rear u-bolts that go around the springs and to the bracket on the rear end are almost deteriorated and one of the mounting holders on the bottom side of the rear end is broken. Does anyone have a set of know where a guy could get some of them? Ill post a picture when I get one here shortly. thanks
09-02-2018, 11:28 PM | #2 |
60-66 Nut
Re: K10 rear U-bolt
For the u-bolts I would just get new ones. Does your lower bracket have the shock mount built into it?
09-04-2018, 01:34 PM | #3 |
Re: K10 rear U-bolt
LMC truck has them in there catalog. need a pic of what's broken.
1961 chevy K10 my build is------------61K10 build |
09-04-2018, 02:17 PM | #4 |
Re: K10 rear U-bolt
I’ll replace the bolts with new, justvneed to measure them and get what I need. But here is a picture of what broke
09-04-2018, 02:39 PM | #5 |
Re: K10 rear U-bolt
I think LMC has the bottom plate also. #8 is the plate. I would call and make sure the u (square) bolts are the correct length. Most spring shops can make them also, as you might know.
09-04-2018, 10:31 PM | #6 |
Re: K10 rear U-bolt
^^^ This.
FWIW, Ive had excellent luck with spring shop u bolts. I have found them to be comparable in price to mail order and seemingly better quality. Most of the time the steel has been made here (USA). Most OTR truck shops also have the bolts or the capability to make them. It surprises me that the bottom plate is still made. Awesome that it still can be found!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
09-04-2018, 11:02 PM | #7 |
Re: K10 rear U-bolt
Yeah I was mostly concerned about that plate, the i bolts I figured I could get pretty easily
09-15-2018, 11:54 PM | #8 |
60-66 Nut
Re: K10 rear U-bolt
Did you find a bottom plate yet? I was doing some clean up today and found one.
