1968 k20 needs help with steering correction
i lifted my 1968 k20 6" closed knuckle front axel manual steering . dont get full right turn ."any advice have pics not sure how to post here
![]() Join Date: Feb 2000
Re: 1968 k20 needs help with steering correction
Adjustable drop drag link is what you need.
Here is a pic of the one on my 69 K20 ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
you may have the pitman arm clocked wrong...easy check...set steering to straight ahead,remove pitman arm from box,now turn either way to stop and count turns while turnig back,should be about 3 1/2 to 4 turns.now find center of travel in steering box and re-install pitman arm/the pitman arm can be installed in four different positions so find the one that is closest to straight.and as JACK said you should have a drop drag link like the one in the picture good luck
