03-15-2022, 12:24 PM | #1 |
greetings from NW Pa
Thanks for adding me! I've been lurking on here for a bit collecting info, great resource!
I work at a small gearing and drivetrain shop that also sells parts for OTR trucks. I make and repair driveshafts, rebuild transfer cases, etc. I will be doing most or all of the needed repairs myself. I found this '66 C20 at an old closed dealership in Ohio. They took it on trade many years ago and it sat inside. It was driven occasionally. The owner knew very little about it. I've been decoding numbers. It's from the Fremont CA plant. I know it's a 327 that has '69 camel hump heads on it. It has an edelbrock performer intake and carb. Factory AC (not operational yet but all there, last priority) and a 700R4 tranny. Eaton HO52 and I believe it's 4.56 ratio according to my calculations (about 2450 rpm at 70 mph in od and torque converter locked) thank god for the OD trans. The body appears to be all original with no bondo. There is surface rust here and there on the underside and the inner rockers have small holes but all in all pretty clean for 55 years old. I rebuilt the distributor, new plugs and wires, put the vacuum lines on the correct ports and she runs pretty sweet. Right now, I'm rebuilding the the front end control arms, ball joints, etc to pass inspection. Me and the wife have been toying with the idea of getting something like this for while and decided F@#$ it life's short!No check engine light...perfect! We plan on cruising and maybe a couple shows. |
03-15-2022, 12:58 PM | #2 |
Re: greetings from NW Pa
...oh ya, I also build and fly RC airplanes and this truck will haul them nicely.
03-15-2022, 02:33 PM | #3 |
Moderator
Welcome to the forum. Great looking truck. Hope to see more of it in the 60-66 section.
03-15-2022, 04:44 PM | #4 |
Catchy title goes here..
The side hobby is pretty cool too. Show them off in the general discussion area. We love pics
03-16-2022, 01:15 AM | #5 |
Welcome! I love the slot mags
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-18-2022, 11:07 AM | #6 |
Clean truck! That's an interesting story about how they took it in on a trade and have kept it for so long. Welcome to the forum!
